I’m using HomeKit with openHAB 3.2 and need some help with Security Accessory. It works fine when I change the mode from the Home app, but shows “Arming” when changed from from openHAB (via CurrentSecuritySystemState). I also set TargetSecuritySystemState to CurrentSecuritySystemState, but it still shows “Arming”. Any help would be appreciated.
how you change it from OpenHAB? via UI or command/rule? if command, which command - sendCommand or postUpdate
Thanks for the quick reply, I found the issue. It was a logic error that resulted in the command not being sent. FWIW, I’m using a script in the UI and either sendCommand or postUpdate correctly update TargetSecuritySystemState in HomeKit.
