I’m using the latest openhab 2.2.0 Snapshot #1102 and have installed the homematic binding via PaperUI. But I can’t establish a connection with the homematic bridge for some reason. I checked the firewall on the CCU2 and I have previously used the binding and bridge successfully with the opehab build 2.1.0.
(Although in the 2.1.0 build for openhab the variables for the homematic gateway and devices didn’t get updated in PaperUI and Basic. I read that I was supposed to update the binding in order to get it to work but I could not get the snapshot version of the binding to work with the openhab build 2.1.0 so that’s the reason for using the latest snapshot of openhab and homematic binding).
I’m on Windows10. This is the TRACE log when starting the homematic binding:
2017-12-01 18:08:32.692 [DEBUG] [org.openhab.binding.homematic ] - BundleEvent STARTING - org.openhab.binding.homematic
2017-12-01 18:08:32.693 [DEBUG] [org.openhab.binding.homematic ] - BundleEvent STARTED - org.openhab.binding.homematic
2017-12-01 18:08:32.701 [DEBUG] [org.openhab.binding.homematic ] - ServiceEvent REGISTERED - {org.openhab.binding.homematic.internal.type.HomematicConfigDescriptionProvider, org.eclipse.smarthome.config.core.ConfigDescriptionProvider}={component.name=org.openhab.binding.homematic.internal.type.HomematicConfigDescriptionProviderImpl, component.id=185, service.id=320, service.bundleid=203, service.scope=bundle} - org.openhab.binding.homematic
2017-12-01 18:08:32.703 [DEBUG] [org.openhab.binding.homematic ] - ServiceEvent REGISTERED - {org.openhab.binding.homematic.internal.type.HomematicChannelTypeProvider, org.eclipse.smarthome.core.thing.type.ChannelTypeProvider}={component.name=org.openhab.binding.homematic.internal.type.HomematicChannelTypeProviderImpl, component.id=186, service.id=321, service.bundleid=203, service.scope=bundle} - org.openhab.binding.homematic
2017-12-01 18:08:32.705 [DEBUG] [org.openhab.binding.homematic ] - ServiceEvent REGISTERED - {org.openhab.binding.homematic.internal.type.HomematicThingTypeProvider, org.eclipse.smarthome.core.thing.binding.ThingTypeProvider}={component.name=org.openhab.binding.homematic.internal.type.HomematicThingTypeProviderImpl, component.id=187, service.id=322, service.bundleid=203, service.scope=bundle} - org.openhab.binding.homematic
2017-12-01 18:08:32.707 [DEBUG] [org.openhab.binding.homematic ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.config.discovery.UpnpDiscoveryParticipant}={component.name=org.openhab.binding.homematic.internal.discovery.HomegearDiscoveryParticipant, component.id=188, service.id=323, service.bundleid=203, service.scope=bundle} - org.openhab.binding.homematic
2017-12-01 18:08:32.709 [DEBUG] [org.openhab.binding.homematic ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.core.thing.binding.ThingHandlerFactory}={component.name=org.openhab.binding.homematic.handler.HomematicThingHandlerFactory, component.id=189, service.id=325, service.bundleid=203, service.scope=bundle} - org.openhab.binding.homematic
2017-12-01 18:08:32.721 [DEBUG] [matic.handler.HomematicBridgeHandler] - HomematicConfig[gatewayAddress=192.168.0.195,callbackHost=192.168.0.175,xmlCallbackPort=9125,binCallbackPort=9126,gatewayType=auto,rfPort=2001,wiredPort=2000,hmIpPort=2010,cuxdPort=8701,groupPort=9292,timeout=15,socketMaxAlive=900]
2017-12-01 18:08:32.722 [TRACE] [matic.handler.HomematicBridgeHandler] - Registering HomematicDeviceDiscoveryService for bridge '6752d3b6'
2017-12-01 18:08:32.723 [DEBUG] [org.openhab.binding.homematic ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.config.discovery.DiscoveryService}={service.id=326, service.bundleid=203, service.scope=singleton} - org.openhab.binding.homematic
2017-12-01 18:08:32.725 [DEBUG] [org.openhab.binding.homematic ] - ServiceEvent REGISTERED - {org.openhab.binding.homematic.internal.type.HomematicTypeGenerator}={component.name=org.openhab.binding.homematic.internal.type.HomematicTypeGeneratorImpl, component.id=190, service.id=324, service.bundleid=203, service.scope=bundle} - org.openhab.binding.homematic
2017-12-01 18:08:32.736 [TRACE] [nal.communicator.client.XmlRpcClient] - Client XmlRpcRequest (port 2001):
<?xml version="1.0" encoding="ISO-8859-1"?>
<methodCall><methodName>getDeviceDescription</methodName>
<params><param><value>BidCoS-RF</value></param></params></methodCall>
2017-12-01 18:08:47.739 [DEBUG] [nal.communicator.client.XmlRpcClient] - XmlRpcMessage failure, sending message again 1/1
2017-12-01 18:09:02.742 [DEBUG] [matic.handler.HomematicBridgeHandler] - Disposing bridge '6752d3b6'
2017-12-01 18:09:02.743 [DEBUG] [very.HomematicDeviceDiscoveryService] - Stopping Homematic discovery scan
Any help on the issue would be much appreciated!
