I have an item for my Homematic HM-CC-RT-DN which i use to put the device into manual mode with a desired temperature value. Item definition with forceUpdate set to true:
Number heating_MANUAL_MODE "Heating Manual [%.1f °C]" <temperature> {channel="homematic:HG-HM-CC-RT-DN:0bxxxxxx:MEQxxxxxxx:4#MANU_MODE", autoUpdate="true", forceUpdate="true"}
If I now update the item via any means to some number, this works. However, if I do the same again (does not matter when), if using the same value, this does not work despite forceUpdate being true.
The log shows the following message:
11:20:21.605 [DEBUG] [ematic.handler.HomematicThingHandler] - Received command '17' for channel 'homematic:HG-HM-CC-RT-DN:0bxxxxxx:MEQxxxxxxx:4#MANU_MODE'
11:20:21.609 [DEBUG] [ternal.communicator.HomematicGateway] - Value '17.0' equals cached gateway value '17.0' with id '0bxxxxxx' and forceUpdate is false, ignoring 'MEQxxxxxxx:4#MANU_MODE'
This is not reallly nice because now the device is not set to manual mode. Setting the item to some other value works of course, but I suppose this problem should not occur in the first, so I suppose this is a bug.
I am using the testing repository and the currently installed version (via apt-cache show openhab2) is called 2.1.0~20170202112846-1. I am using the addon that is bundled with that version as far as I can tell.
Can you try to set forceUpdate in PaperUI? You can enable it by editing a channel. According to the log message it seems that the forceUpdate setting in the item definition is ignored. I think it only possible to set it for a channel.
I tried to, but honestly I have no clue where to edit that in the UI. I loaded the URL https://myhost/paperui/index.html#/configuration/things/edit/homematic:HG-HM-CC-RT-DN:0bxxxxxx:MEQxxxxxxx and there is the thing configuration for that wireless heating thermostat located. At the bottom of the page you can even en- or disable AES encryption for some channels (but I am sure this means homematic channels and not OpenHAB channels).
But there is no possibility to view or change this certain channel property we are talking about (as far as I can tell).
