@MHerbst, quick follow-up question on this: I’m running openHAB on Raspi/docker with CCU2 for almost 1,5 years now, and I do not recall that I had this problem from the beginning. You sure it’s not something else? Anything else I could do/log/test to help resolving this, to not go for the “temporary bypass” or wait for someone to re-implement the connect handling?
Edit: Disabling things from rules is not as easy as I thought (I hit this roadblock as well).
Edit 2: After installing the ECMA Script 2021, this worked fine. Only “problems” is a slight delay / log entry (Failed to retrieve script script dependency listener from engine bindings. Script dependency tracking will be disabled." (also described here).
