i have a pi3 with openhabian Image and installed the newest stable piVCCU ( CCU3 ). But the binding cannot find the CCU automatically. If i add the Thing manually, the gateway will be offline few minutes later. The CCU runs like a charm. I can add things and control them. If the CCU-Gateway is online in openhab, i can control the things via openhab too. but after some minutes the bridge goes offline.
Normally the binding should find the gateway autmatically souldnt it? this is the first step that dont work.
i hope you can help me
2018-11-10 17:11:03.365 [INFO ] [er.internal.HomeBuilderDashboardTile] - Started Home Builder at /homebuilder
2018-11-10 17:11:05.324 [INFO ] [.dashboard.internal.DashboardService] - Started Dashboard at http://192.168.2.118:8080
2018-11-10 17:11:05.329 [INFO ] [.dashboard.internal.DashboardService] - Started Dashboard at https://192.168.2.118:8443
2018-11-10 17:11:28.515 [INFO ] [thome.model.lsp.internal.ModelServer] - Started Language Server Protocol (LSP) service on port 5007
2018-11-10 17:11:31.963 [INFO ] [basic.internal.servlet.WebAppServlet] - Started Basic UI at /basicui/app
2018-11-10 17:11:32.176 [INFO ] [arthome.ui.paper.internal.PaperUIApp] - Started Paper UI at /paperui
2018-11-10 17:11:32.986 [INFO ] [panel.internal.HABPanelDashboardTile] - Started HABPanel at /habpanel
2018-11-10 17:11:33.311 [INFO ] [ttp.internal.SecureHttpClientFactory] - creating httpClient for endpoint null
2018-11-10 17:11:33.392 [INFO ] [ttp.internal.SecureHttpClientFactory] - jetty shared http client created
2018-11-10 17:25:18.218 [hingStatusInfoChangedEvent] - 'homematic:bridge:3a6cb74b' changed from UNINITIALIZED to INITIALIZING
2018-11-10 17:25:18.537 [INFO ] [ternal.communicator.client.RpcClient] - Interface 'WIRED' on gateway '3a6cb74b' not available, disabling support
2018-11-10 17:25:18.563 [INFO ] [ternal.communicator.client.RpcClient] - Interface 'CUXD' on gateway '3a6cb74b' not available, disabling support
2018-11-10 17:25:18.630 [WARN ] [l.BatteryTypeVirtualDatapointHandler] - Battery property file not found, battery type not available
2018-11-10 17:25:18.726 [INFO ] [ommunicator.AbstractHomematicGateway] - HmGatewayInfo[id=CCU,type=CCU2,firmware=3.37.8,address=PEQ0531543,wired=false,hmip=true,cuxd=false,group=true]
2018-11-10 17:25:29.216 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing 'homematic:HM-RCV-50:3a6cb74b:BidCoS-RF' to inbox.
2018-11-10 17:25:29.218 [home.event.InboxAddedEvent] - Discovery Result with UID 'homematic:HM-RCV-50:3a6cb74b:BidCoS-RF' has been added.
2018-11-10 17:25:29.251 [INFO ] [ng.homematic.internal.misc.MiscUtils] - Datapoint name '${sysVarAlarmZone1}' contains invalid characters, new Datapoint name '__sysVarAlarmZone1_'
2018-11-10 17:25:29.261 [INFO ] [ng.homematic.internal.misc.MiscUtils] - Datapoint name '${sysVarPresence}' contains invalid characters, new Datapoint name '__sysVarPresence_'
2018-11-10 17:25:29.299 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing 'homematic:GATEWAY-EXTRAS-3A6CB74B:3a6cb74b:GWE00000000' to inbox.
2018-11-10 17:25:29.299 [home.event.InboxAddedEvent] - Discovery Result with UID 'homematic:GATEWAY-EXTRAS-3A6CB74B:3a6cb74b:GWE00000000' has been added.
2018-11-10 17:25:29.316 [hingStatusInfoChangedEvent] - 'homematic:bridge:3a6cb74b' changed from INITIALIZING to ONLINE
2018-11-10 17:25:35.914 [me.event.InboxRemovedEvent] - Discovery Result with UID 'homematic:GATEWAY-EXTRAS-3A6CB74B:3a6cb74b:GWE00000000' has been removed.
2018-11-10 17:25:35.971 [hingStatusInfoChangedEvent] - 'homematic:GATEWAY-EXTRAS-3A6CB74B:3a6cb74b:GWE00000000' changed from UNINITIALIZED to INITIALIZING
2018-11-10 17:25:35.996 [hingStatusInfoChangedEvent] - 'homematic:GATEWAY-EXTRAS-3A6CB74B:3a6cb74b:GWE00000000' changed from INITIALIZING to ONLINE
2018-11-10 17:25:36.042 [me.event.ThingUpdatedEvent] - Thing 'homematic:GATEWAY-EXTRAS-3A6CB74B:3a6cb74b:GWE00000000' has been updated.
2018-11-10 17:25:38.166 [me.event.InboxRemovedEvent] - Discovery Result with UID 'homematic:HM-RCV-50:3a6cb74b:BidCoS-RF' has been removed.
2018-11-10 17:25:38.278 [hingStatusInfoChangedEvent] - 'homematic:HM-RCV-50:3a6cb74b:BidCoS-RF' changed from UNINITIALIZED to INITIALIZING
2018-11-10 17:25:38.298 [hingStatusInfoChangedEvent] - 'homematic:HM-RCV-50:3a6cb74b:BidCoS-RF' changed from INITIALIZING to ONLINE
2018-11-10 17:25:38.684 [me.event.ThingUpdatedEvent] - Thing 'homematic:HM-RCV-50:3a6cb74b:BidCoS-RF' has been updated.
2018-11-10 17:25:38.892 [me.event.ThingUpdatedEvent] - Thing 'homematic:HM-RCV-50:3a6cb74b:BidCoS-RF' has been updated.
2018-11-10 17:26:14.324 [WARN ] [ommunicator.AbstractHomematicGateway] - Connection lost on gateway '3a6cb74b'
2018-11-10 17:26:14.344 [hingStatusInfoChangedEvent] - 'homematic:bridge:3a6cb74b' changed from ONLINE to OFFLINE (COMMUNICATION_ERROR): Connection lost
2018-11-10 17:26:14.361 [hingStatusInfoChangedEvent] - 'homematic:GATEWAY-EXTRAS-3A6CB74B:3a6cb74b:GWE00000000' changed from ONLINE to OFFLINE (BRIDGE_OFFLINE)
2018-11-10 17:26:14.368 [hingStatusInfoChangedEvent] - 'homematic:HM-RCV-50:3a6cb74b:BidCoS-RF' changed from ONLINE to OFFLINE (BRIDGE_OFFLINE)
