Hi, I’m using OpenHab 1.8.3 together with homegear. The homematic communicator is restarted every minute:
2016-10-21 09:13:35.048 [INFO ] [.b.h.i.c.HomematicCommunicator] - Starting Homematic communicator
2016-10-21 09:13:35.071 [INFO ] [.b.h.i.c.HomematicCommunicator] - Homematic ServerId[name=Homegear,version=0.6 .7-1480]
2016-10-21 09:13:35.073 [INFO ] [.b.h.i.c.client.HomegearClient] - Starting HomegearClient
2016-10-21 09:13:35.087 [INFO ] [b.h.i.communicator.StateHolder] - Loading Homematic datapoints
2016-10-21 09:13:35.533 [INFO ] [b.h.i.communicator.StateHolder] - Finished loading 174 Homematic datapoints
2016-10-21 09:13:35.540 [INFO ] [b.h.i.communicator.StateHolder] - Loading Homematic Server variables
2016-10-21 09:13:35.565 [INFO ] [b.h.i.communicator.StateHolder] - Finished loading 0 Homematic server variable s
2016-10-21 09:13:35.567 [INFO ] [b.h.i.c.s.BinRpcCallbackServer] - Starting BinRpcCallbackServer at port 9123
2016-10-21 09:13:35.615 [INFO ] [.b.h.i.c.HomematicCommunicator] - Scheduling one datapoint reload job in one m inute
2016-10-21 09:14:35.619 [INFO ] [o.o.b.h.i.bus.HomematicBinding] - No event since 1239 seconds, refreshing Home matic server connections
2016-10-21 09:14:35.622 [INFO ] [.b.h.i.c.HomematicCommunicator] - Shutting down Homematic communicator
2016-10-21 09:14:35.643 [INFO ] [.b.h.i.c.HomematicCommunicator] - Starting Homematic communicator
2016-10-21 09:14:35.659 [INFO ] [.b.h.i.c.HomematicCommunicator] - Homematic ServerId[name=Homegear,version=0.6 .7-1480]
2016-10-21 09:14:35.661 [INFO ] [.b.h.i.c.client.HomegearClient] - Starting HomegearClient
2016-10-21 09:14:35.664 [INFO ] [b.h.i.communicator.StateHolder] - Loading Homematic datapoints
2016-10-21 09:14:36.076 [INFO ] [b.h.i.communicator.StateHolder] - Finished loading 174 Homematic datapoints
2016-10-21 09:14:36.079 [INFO ] [b.h.i.communicator.StateHolder] - Loading Homematic Server variables
2016-10-21 09:14:36.096 [INFO ] [b.h.i.communicator.StateHolder] - Finished loading 0 Homematic server variable s
2016-10-21 09:14:36.099 [INFO ] [b.h.i.c.s.BinRpcCallbackServer] - Starting BinRpcCallbackServer at port 9123
2016-10-21 09:14:36.116 [INFO ] [.b.h.i.c.HomematicCommunicator] - Scheduling one datapoint reload job in one m inute
2016-10-21 09:15:36.134 [INFO ] [o.o.b.h.i.bus.HomematicBinding] - No event since 1300 seconds, refreshing Home matic server connections
2016-10-21 09:15:36.137 [INFO ] [.b.h.i.c.HomematicCommunicator] - Shutting down Homematic communicator
2016-10-21 09:15:36.208 [INFO ] [.b.h.i.c.HomematicCommunicator] - Starting Homematic communicator
2016-10-21 09:15:36.259 [INFO ] [.b.h.i.c.HomematicCommunicator] - Homematic ServerId[name=Homegear,version=0.6 .7-1480]
2016-10-21 09:15:36.262 [INFO ] [.b.h.i.c.client.HomegearClient] - Starting HomegearClient
2016-10-21 09:15:36.278 [INFO ] [b.h.i.communicator.StateHolder] - Loading Homematic datapoints
2016-10-21 09:15:37.779 [INFO ] [b.h.i.communicator.StateHolder] - Finished loading 174 Homematic datapoints
2016-10-21 09:15:37.782 [INFO ] [b.h.i.communicator.StateHolder] - Loading Homematic Server variables
2016-10-21 09:15:37.910 [INFO ] [b.h.i.communicator.StateHolder] - Finished loading 0 Homematic server variable s
2016-10-21 09:15:37.947 [INFO ] [b.h.i.c.s.BinRpcCallbackServer] - Starting BinRpcCallbackServer at port 9123
2016-10-21 09:15:38.014 [INFO ] [.b.h.i.c.HomematicCommunicator] - Scheduling one datapoint reload job in one m inute
2016-10-21 09:16:38.060 [INFO ] [o.o.b.h.i.bus.HomematicBinding] - No event since 1362 seconds, refreshing Home matic server connections
2016-10-21 09:16:38.062 [INFO ] [.b.h.i.c.HomematicCommunicator] - Shutting down Homematic communicator
2016-10-21 09:16:38.108 [INFO ] [.b.h.i.c.HomematicCommunicator] - Starting Homematic communicator
2016-10-21 09:16:38.185 [INFO ] [.b.h.i.c.HomematicCommunicator] - Homematic ServerId[name=Homegear,version=0.6 .7-1480]
2016-10-21 09:16:38.187 [INFO ] [.b.h.i.c.client.HomegearClient] - Starting HomegearClient
2016-10-21 09:16:38.190 [INFO ] [b.h.i.communicator.StateHolder] - Loading Homematic datapoints
2016-10-21 09:16:39.856 [INFO ] [b.h.i.communicator.StateHolder] - Finished loading 174 Homematic datapoints
2016-10-21 09:16:39.859 [INFO ] [b.h.i.communicator.StateHolder] - Loading Homematic Server variables
2016-10-21 09:16:39.911 [INFO ] [b.h.i.communicator.StateHolder] - Finished loading 0 Homematic server variable s
2016-10-21 09:16:39.934 [INFO ] [b.h.i.c.s.BinRpcCallbackServer] - Starting BinRpcCallbackServer at port 9123
2016-10-21 09:16:39.955 [INFO ] [.b.h.i.c.HomematicCommunicator] - Scheduling one datapoint reload job in one m inute
2016-10-21 09:17:39.994 [INFO ] [o.o.b.h.i.bus.HomematicBinding] - No event since 1424 seconds, refreshing Home matic server connections
2016-10-21 09:17:39.997 [INFO ] [.b.h.i.c.HomematicCommunicator] - Shutting down Homematic communicator
2016-10-21 09:17:40.018 [INFO ] [.b.h.i.c.HomematicCommunicator] - Starting Homematic communicator
2016-10-21 09:17:40.036 [INFO ] [.b.h.i.c.HomematicCommunicator] - Homematic ServerId[name=Homegear,version=0.6 .7-1480]
2016-10-21 09:17:40.039 [INFO ] [.b.h.i.c.client.HomegearClient] - Starting HomegearClient
2016-10-21 09:17:40.041 [INFO ] [b.h.i.communicator.StateHolder] - Loading Homematic datapoints
2016-10-21 09:17:40.457 [INFO ] [b.h.i.communicator.StateHolder] - Finished loading 174 Homematic datapoints
2016-10-21 09:17:40.460 [INFO ] [b.h.i.communicator.StateHolder] - Loading Homematic Server variables
2016-10-21 09:17:40.479 [INFO ] [b.h.i.communicator.StateHolder] - Finished loading 0 Homematic server variable s
2016-10-21 09:17:40.482 [INFO ] [b.h.i.c.s.BinRpcCallbackServer] - Starting BinRpcCallbackServer at port 9123
2016-10-21 09:17:40.510 [INFO ] [.b.h.i.c.HomematicCommunicator] - Scheduling one datapoint reload job in one m inute
2016-10-21 09:18:40.514 [INFO ] [o.o.b.h.i.bus.HomematicBinding] - No event since 1484 seconds, refreshing Home matic server connections
2016-10-21 09:18:40.516 [INFO ] [.b.h.i.c.HomematicCommunicator] - Shutting down Homematic communicator
2016-10-21 09:18:40.536 [INFO ] [.b.h.i.c.HomematicCommunicator] - Starting Homematic communicator
2016-10-21 09:18:40.560 [INFO ] [.b.h.i.c.HomematicCommunicator] - Homematic ServerId[name=Homegear,version=0.6 .7-1480]
2016-10-21 09:18:40.563 [INFO ] [.b.h.i.c.client.HomegearClient] - Starting HomegearClient
2016-10-21 09:18:40.566 [INFO ] [b.h.i.communicator.StateHolder] - Loading Homematic datapoints
2016-10-21 09:18:40.958 [INFO ] [b.h.i.communicator.StateHolder] - Finished loading 174 Homematic datapoints
2016-10-21 09:18:40.960 [INFO ] [b.h.i.communicator.StateHolder] - Loading Homematic Server variables
2016-10-21 09:18:40.978 [INFO ] [b.h.i.communicator.StateHolder] - Finished loading 0 Homematic server variable s
2016-10-21 09:18:40.981 [INFO ] [b.h.i.c.s.BinRpcCallbackServer] - Starting BinRpcCallbackServer at port 9123
2016-10-21 09:18:40.998 [INFO ] [.b.h.i.c.HomematicCommunicator] - Scheduling one datapoint reload job in one m inute
Is this a normal behaviour?
