Hello guys,
I don’t get the homematic binding working stable since I updated to openhab 3.
With my previous openhab 2 setting everything worked well, but with the new openhab 3 installation the homematic binding works for a few hours, but after a period of time it stops working and I get a lot of messages in the logs. To make the binding work again, I have to reboot the system.
I have an original CCU3. Openhab runs on a raspberry pi 3b. Both are connected via Lan to a Fritzbox 7530. Actually i have the lastest 3.2 Milestone installed, but I also tried it with openhab 3.1. The binding is set up via the UI like its explained in the Documentation.
Here is what my log shows. Maybe someone can help me.
2021-09-15 22:02:46.803 [DEBUG] [nal.communicator.client.XmlRpcClient] - XmlRpcMessage failed, sending message again 1/3
2021-09-15 22:03:01.807 [DEBUG] [nal.communicator.client.XmlRpcClient] - XmlRpcMessage failed, sending message again 2/3
2021-09-15 22:03:16.810 [DEBUG] [nal.communicator.client.XmlRpcClient] - XmlRpcMessage failed, sending message again 3/3
2021-09-15 22:03:31.813 [DEBUG] [ommunicator.AbstractHomematicGateway] - Unable to release the connection to the gateway with id '3014F711A0001F98A9A6E6CE': java.util.concurrent.TimeoutException
java.io.IOException: java.util.concurrent.TimeoutException
at org.openhab.binding.homematic.internal.communicator.client.XmlRpcClient.send(XmlRpcClient.java:122) ~[bundleFile:?]
at org.openhab.binding.homematic.internal.communicator.client.XmlRpcClient.sendMessage(XmlRpcClient.java:77) ~[bundleFile:?]
at org.openhab.binding.homematic.internal.communicator.client.RpcClient.release(RpcClient.java:102) ~[bundleFile:?]
at org.openhab.binding.homematic.internal.communicator.AbstractHomematicGateway.stopServers(AbstractHomematicGateway.java:267) [bundleFile:?]
at org.openhab.binding.homematic.internal.communicator.AbstractHomematicGateway$ConnectionTrackerThread.handleInvalidConnection(AbstractHomematicGateway.java:933) [bundleFile:?]
at org.openhab.binding.homematic.internal.communicator.AbstractHomematicGateway$ConnectionTrackerThread.run(AbstractHomematicGateway.java:912) [bundleFile:?]
at java.util.concurrent.FutureTask.runAndReset(FutureTask.java:305) [?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:305) [?:?]
Caused by: java.util.concurrent.TimeoutException
at org.eclipse.jetty.client.util.FutureResponseListener.get(FutureResponseListener.java:109) ~[bundleFile:9.4.40.v20210413]
at org.openhab.binding.homematic.internal.communicator.client.XmlRpcClient.send(XmlRpcClient.java:112) ~[bundleFile:?]
... 11 more
2021-09-15 22:03:46.819 [DEBUG] [ommunicator.AbstractHomematicGateway] - Unable to release the connection to the gateway with id '3014F711A0001F98A9A6E6CE': java.util.concurrent.TimeoutException
... 11 more
2021-09-15 22:04:01.825 [DEBUG] [ommunicator.AbstractHomematicGateway] - Unable to release the connection to the gateway with id '3014F711A0001F98A9A6E6CE': java.util.concurrent.TimeoutException
... 11 more
2021-09-15 22:04:01.829 [DEBUG] [nal.communicator.server.XmlRpcServer] - Stopping XML-RPC server
2021-09-15 22:04:01.842 [DEBUG] [nal.communicator.server.XmlRpcServer] - Initializing XML-RPC server at port 9125
2021-09-15 22:04:46.858 [DEBUG] [nal.communicator.client.XmlRpcClient] - XmlRpcMessage failed, sending message again 1/3
2021-09-15 22:05:01.861 [DEBUG] [nal.communicator.client.XmlRpcClient] - XmlRpcMessage failed, sending message again 2/3
2021-09-15 22:05:16.864 [DEBUG] [nal.communicator.client.XmlRpcClient] - XmlRpcMessage failed, sending message again 3/3
and if i am waiting for a longer time without rebooting, the log shows the following:
2021-09-19 18:54:27.618 [DEBUG] [ernal.handler.HomematicBridgeHandler] - Disposing bridge '3014F711A0001F98A9A6E6CE'
2021-09-19 18:54:27.618 [DEBUG] [very.HomematicDeviceDiscoveryService] - Stopping Homematic discovery scan
2021-09-19 18:54:27.619 [DEBUG] [very.HomematicDeviceDiscoveryService] - Waiting for finishing Homematic device discovery scan
2021-09-19 18:54:27.619 [DEBUG] [very.HomematicDeviceDiscoveryService] - Finished Homematic device discovery scan on gateway '3014F711A0001F98A9A6E6CE'
2021-09-19 18:54:37.621 [DEBUG] [ernal.handler.HomematicBridgeHandler] - HomematicConfig[gatewayAddress=192.168.178.31,callbackHost=192.168.178.43,xmlCallbackPort=9125,binCallbackPort=9126,gatewayType=auto,rfPort=2001,wiredPort=2000,hmIpPort=2010,cuxdPort=8701,groupPort=9292,timeout=15,discoveryTimeToLive=-1,installModeDuration=60,socketMaxAlive=900]
2021-09-19 18:54:37.624 [DEBUG] [nal.communicator.client.XmlRpcClient] - XmlRpcMessage failed, sending message again 1/3
2021-09-19 18:54:37.626 [DEBUG] [nal.communicator.client.XmlRpcClient] - XmlRpcMessage failed, sending message again 2/3
2021-09-19 18:54:37.629 [DEBUG] [nal.communicator.client.XmlRpcClient] - XmlRpcMessage failed, sending message again 3/3
2021-09-19 18:54:37.632 [DEBUG] [nal.communicator.client.XmlRpcClient] - XmlRpcMessage failed, sending message again 1/3
2021-09-19 18:54:37.635 [DEBUG] [nal.communicator.client.XmlRpcClient] - XmlRpcMessage failed, sending message again 2/3
2021-09-19 18:54:37.637 [DEBUG] [nal.communicator.client.XmlRpcClient] - XmlRpcMessage failed, sending message again 3/3
2021-09-19 18:54:37.638 [DEBUG] [nal.communicator.client.XmlRpcClient] - XmlRpcMessage failed, sending message again 1/3
2021-09-19 18:54:37.640 [DEBUG] [nal.communicator.client.XmlRpcClient] - XmlRpcMessage failed, sending message again 2/3
2021-09-19 18:54:37.642 [DEBUG] [nal.communicator.client.XmlRpcClient] - XmlRpcMessage failed, sending message again 3/3
2021-09-19 18:54:37.643 [DEBUG] [ernal.handler.HomematicBridgeHandler] - Homematic bridge was set to OFFLINE-COMMUNICATION_ERROR due to the following exception: java.util.concurrent.ExecutionException: java.util.concurrent.RejectedExecutionException: Max requests queued per destination 1024 exceeded for HttpDestination[http://192.168.178.31:2010]@170e09e,queue=1024,pool=DuplexConnectionPool@655529[c=2/2/2,a=0,i=0,q=1024]
java.io.IOException: java.util.concurrent.ExecutionException: java.util.concurrent.RejectedExecutionException: Max requests queued per destination 1024 exceeded for HttpDestination[http://192.168.178.31:2010]@170e09e,queue=1024,pool=DuplexConnectionPool@655529[c=2/2/2,a=0,i=0,q=1024]
at org.openhab.binding.homematic.internal.communicator.client.XmlRpcClient.send(XmlRpcClient.java:122) ~[?:?]
at org.openhab.binding.homematic.internal.communicator.client.XmlRpcClient.sendMessage(XmlRpcClient.java:77) ~[?:?]
at org.openhab.binding.homematic.internal.communicator.client.RpcClient.listBidcosInterfaces(RpcClient.java:119) ~[?:?]
at org.openhab.binding.homematic.internal.communicator.client.RpcClient.getGatewayInfo(RpcClient.java:245) ~[?:?]
at org.openhab.binding.homematic.internal.communicator.HomematicGatewayFactory.loadGatewayInfo(HomematicGatewayFactory.java:50) ~[?:?]
at org.openhab.binding.homematic.internal.communicator.HomematicGatewayFactory.createGateway(HomematicGatewayFactory.java:34) ~[?:?]
at org.openhab.binding.homematic.internal.handler.HomematicBridgeHandler.initializeInternal(HomematicBridgeHandler.java:109) ~[?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:304) [?:?]
Caused by: java.util.concurrent.ExecutionException: java.util.concurrent.RejectedExecutionException: Max requests queued per destination 1024 exceeded for HttpDestination[http://192.168.178.31:2010]@170e09e,queue=1024,pool=DuplexConnectionPool@655529[c=2/2/2,a=0,i=0,q=1024]
at org.eclipse.jetty.client.util.FutureResponseListener.getResult(FutureResponseListener.java:118) ~[?:?]
at org.eclipse.jetty.client.util.FutureResponseListener.get(FutureResponseListener.java:110) ~[?:?]
at org.openhab.binding.homematic.internal.communicator.client.XmlRpcClient.send(XmlRpcClient.java:112) ~[?:?]
... 12 more
Caused by: java.util.concurrent.RejectedExecutionException: Max requests queued per destination 1024 exceeded for HttpDestination[http://192.168.178.31:2010]@170e09e,queue=1024,pool=DuplexConnectionPool@655529[c=2/2/2,a=0,i=0,q=1024]
at org.eclipse.jetty.client.HttpDestination.send(HttpDestination.java:293) ~[?:?]
at org.eclipse.jetty.client.HttpDestination.send(HttpDestination.java:263) ~[?:?]
at org.eclipse.jetty.client.HttpClient.send(HttpClient.java:600) ~[?:?]
at org.eclipse.jetty.client.HttpRequest.sendAsync(HttpRequest.java:778) ~[?:?]
at org.eclipse.jetty.client.HttpRequest.send(HttpRequest.java:765) ~[?:?]
at org.openhab.binding.homematic.internal.communicator.client.XmlRpcClient.send(XmlRpcClient.java:111) ~[?:?]
... 12 more
