i have few system variables who stored values about my GAS consumption. They will be updated by programs on the ccu itsself. the ccu is a piVCCU one the same raspberry. the calculated values from the program of the cpu does not appear in openhab. i have to switch the “Reload All From Gateway” on the gui to get the newest variable values.
if i trigger the “Reload All From Gateway” via a rule (every 5 minutes), the variable values will not be updated. if i trigger it manually via the gui, the values will be updated fine.
