Hi Everyone,
Does anybody know, if the new Version of XML-API Addon 2.0 for Raspberrymatic / CCU
will work with the Homematic Binding?
Cheers,
Tim
Hi Everyone,
Cheers,
Tim
The XML-API 2.0 lists as a breaking change, that a token based authentication must be used to access the API. Currently the bridge does not support a token configuration. So I guess that the binding will not work after upgrading.
I thought the same, when I asked the question, but I’m not even sure, if the binding is using the XML-API. I think there is a difference to the XML-RPC-API and that might be, what the binding is using.
From my understanding:
Maybe someone can bring some light into this.
Openhab is using XML-RPC-API. XML-API 1.X or 2.0 is a different thing for other third party software for homematic etc tinymatic. Openhab dont uses XML-API.
Thanks for the confirmation. A friend of mine told me today, that he already updated the addon without any issue regarding openHAB.
