I have been trying to reinstall the homematic bridge as it was not working after I changed the callback-host address to see if I could get the items values to update in paperUI, and then saved. I have downloaded the latest SNAPSHOT ( 2.2.0.201711171328) of the binding and verified that it is active with the console. The problem now is that the bridge is not initializing, it’s showing an “ERROR 500- Internal server error”.
Part of the error log:
2017-11-17 19:22:24.844 [ERROR] [ome.io.rest.core.thing.ThingResource] - Exception during HTTP PUT request for update config at 'things/homematic:bridge:9723d911/config' for thing 'homematic:bridge:9723d911': Thing with UID homematic:bridge:9723d911 has no handler attached.
2017-11-17 19:22:24.845 [DEBUG] [e.internal.WriterInterceptorExecutor] - Message body writer (class org.eclipse.smarthome.io.rest.core.internal.GsonProvider) is trying to close the entity output stream. Not closing.
2017-11-17 19:22:24.845 [DEBUG] [.eclipse.jetty.server.HttpConnection] - org.eclipse.jetty.server.HttpConnection$SendCallback@197b03b1[PROCESSING][i=ResponseInfo{HTTP/1.1 500 Internal Server Error,105,false},cb=org.eclipse.jetty.server.HttpChannel$CommitCallback@13505bb9] generate: NEED_HEADER (null,[p=0,l=105,c=8192,r=105],true)@START
2017-11-17 19:22:24.845 [DEBUG] [.eclipse.jetty.server.HttpConnection] - org.eclipse.jetty.server.HttpConnection$SendCallback@197b03b1[PROCESSING][i=ResponseInfo{HTTP/1.1 500 Internal Server Error,105,false},cb=org.eclipse.jetty.server.HttpChannel$CommitCallback@13505bb9] generate: FLUSH ([p=0,l=124,c=8192,r=124],[p=0,l=105,c=8192,r=105],true)@COMPLETING
2017-11-17 19:22:24.845 [DEBUG] [org.eclipse.jetty.io.WriteFlusher ] - write: WriteFlusher@4a7ea73a{IDLE} [HeapByteBuffer@8f072d9[p=0,l=124,c=8192,r=124]={<<<HTTP/1.1 500 Inte....v20160908)\r\n\r\n>>>\n8000\r\nth: 289\r\nS...\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00},HeapByteBuffer@5c3bf22d[p=0,l=105,c=8192,r=105]={<<<{"error":{"messag...ttp-code":500}}>>>\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00...\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00}]
2017-11-17 19:22:24.845 [DEBUG] [org.eclipse.jetty.io.WriteFlusher ] - update WriteFlusher@4a7ea73a{WRITING}:IDLE-->WRITING
2017-11-17 19:22:24.845 [DEBUG] [g.eclipse.jetty.io.ssl.SslConnection] - SslConnection@48c94984{NOT_HANDSHAKING,eio=-1/-1,di=-1} -> HttpConnection@16cabe63[FILLING,DecryptedEndPoint@16991896{/192.168.0.175:50409<->8443,Open,in,out,-,W,1164/30000,HttpConnection}->SelectChannelEndPoint@439f6e36{/192.168.0.175:50409<->8443,Open,in,out,-,-,7/30000,SslConnection}{io=0,kio=0,kro=1}][p=HttpParser{s=END,235 of 235},g=HttpGenerator{s=COMPLETING},c=HttpChannelOverHttp@599a6af3{r=4,c=true,a=DISPATCHED,uri=/rest/things/homematic:bridge:9723d911/config}] flush enter [java.nio.HeapByteBuffer[pos=0 lim=124 cap=8192], java.nio.HeapByteBuffer[pos=0 lim=105 cap=8192]]
2017-11-17 19:22:24.845 [DEBUG] [g.eclipse.jetty.io.ssl.SslConnection] - SslConnection@48c94984{NOT_HANDSHAKING,eio=-1/258,di=-1} -> HttpConnection@16cabe63[FILLING,DecryptedEndPoint@16991896{/192.168.0.175:50409<->8443,Open,in,out,-,W,1164/30000,HttpConnection}->SelectChannelEndPoint@439f6e36{/192.168.0.175:50409<->8443,Open,in,out,-,-,7/30000,SslConnection}{io=0,kio=0,kro=1}][p=HttpParser{s=END,235 of 235},g=HttpGenerator{s=COMPLETING},c=HttpChannelOverHttp@599a6af3{r=4,c=true,a=DISPATCHED,uri=/rest/things/homematic:bridge:9723d911/config}] wrap Status = OK HandshakeStatus = NOT_HANDSHAKING
bytesConsumed = 229 bytesProduced = 258
2017-11-17 19:22:24.845 [DEBUG] [g.eclipse.jetty.io.ssl.SslConnection] - DecryptedEndPoint@16991896{/192.168.0.175:50409<->8443,Open,in,out,-,W,1164/30000,HttpConnection}->SelectChannelEndPoint@439f6e36{/192.168.0.175:50409<->8443,Open,in,out,-,-,7/30000,SslConnection}{io=0,kio=0,kro=1} OK HeapByteBuffer@4955c3d3[p=0,l=258,c=17408,r=258]={<<<\x17\x03\x03\x00\xFd\x00\x00\x00\x00\x00\x00\x00\t\xCcUO/...\xF6\xAe\xB0B\xC0\x96\xC7!c"\x9d\x92}\x12\xC4>>> like Gecko) Chro...\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00}
2017-11-17 19:22:24.846 [DEBUG] [org.eclipse.jetty.io.ChannelEndPoint] - flushed 258 SelectChannelEndPoint@439f6e36{/192.168.0.175:50409<->8443,Open,in,out,-,-,8/30000,SslConnection}{io=0,kio=0,kro=1}
2017-11-17 19:22:24.846 [DEBUG] [g.eclipse.jetty.io.ssl.SslConnection] - SslConnection@48c94984{NOT_HANDSHAKING,eio=-1/0,di=-1} -> HttpConnection@16cabe63[FILLING,DecryptedEndPoint@16991896{/192.168.0.175:50409<->8443,Open,in,out,-,W,1165/30000,HttpConnection}->SelectChannelEndPoint@439f6e36{/192.168.0.175:50409<->8443,Open,in,out,-,-,0/30000,SslConnection}{io=0,kio=0,kro=1}][p=HttpParser{s=END,235 of 235},g=HttpGenerator{s=COMPLETING},c=HttpChannelOverHttp@599a6af3{r=4,c=true,a=DISPATCHED,uri=/rest/things/homematic:bridge:9723d911/config}] flush exit, consumed 229
2017-11-17 19:22:24.846 [DEBUG] [org.eclipse.jetty.io.WriteFlusher ] - update WriteFlusher@4a7ea73a{IDLE}:WRITING-->IDLE
2017-11-17 19:22:24.846 [DEBUG] [.eclipse.jetty.server.HttpConnection] - org.eclipse.jetty.server.HttpConnection$SendCallback@197b03b1[PROCESSING][i=ResponseInfo{HTTP/1.1 500 Internal Server Error,105,false},cb=org.eclipse.jetty.server.HttpChannel$CommitCallback@13505bb9] generate: DONE ([p=124,l=124,c=8192,r=0],[p=105,l=105,c=8192,r=0],true)@END
2017-11-17 19:22:24.846 [DEBUG] [.jetty.server.handler.ContextHandler] - scope null||/rest/things/homematic:bridge:9723d911/config @ o.e.j.s.h.ContextHandler@72353f8{/static,null,AVAILABLE}
2017-11-17 19:22:24.846 [DEBUG] [.jetty.server.handler.ContextHandler] - scope null||/rest/things/homematic:bridge:9723d911/config @ HttpServiceContext{httpContext=DefaultHttpContext [bundle=org.eclipse.smarthome.core.audio_0.9.0.b5 [99], contextID=default]}
2017-11-17 19:22:24.846 [DEBUG] [.jetty.server.handler.ContextHandler] - scope null||/rest/things/homematic:bridge:9723d911/config @ HttpServiceContext{httpContext=DefaultHttpContext [bundle=org.eclipse.smarthome.ui_0.9.0.b5 [136], contextID=default]}
2017-11-17 19:22:24.846 [DEBUG] [.jetty.server.handler.ContextHandler] - scope null||/rest/things/homematic:bridge:9723d911/config @ HttpServiceContext{httpContext=DefaultHttpContext [bundle=org.eclipse.smarthome.ui.icon_0.9.0.b5 [137], contextID=default]}
2017-11-17 19:22:24.846 [DEBUG] [.jetty.server.handler.ContextHandler] - scope null||/rest/things/homematic:bridge:9723d911/config @ HttpServiceContext{httpContext=org.jupnp.transport.impl.osgi.DisableAuthenticationHttpContext@6782e51b}
2017-11-17 19:22:24.846 [DEBUG] [.jetty.server.handler.ContextHandler] - scope null||/rest/things/homematic:bridge:9723d911/config @ HttpServiceContext{httpContext=DefaultHttpContext [bundle=org.openhab.ui.dashboard_2.1.0 [170], contextID=default]}
2017-11-17 19:22:24.846 [DEBUG] [.jetty.server.handler.ContextHandler] - scope null||/rest/things/homematic:bridge:9723d911/config @ HttpServiceContext{httpContext=DefaultHttpContext [bundle=org.eclipse.smarthome.ui.basic_0.9.0.b5 [176], contextID=default]}
2017-11-17 19:22:24.846 [DEBUG] [.jetty.server.handler.ContextHandler] - scope null||/rest/things/homematic:bridge:9723d911/config @ HttpServiceContext{httpContext=DefaultHttpContext [bundle=org.eclipse.smarthome.ui.paper_0.9.0.b5 [177], contextID=default]}
2017-11-17 19:22:24.846 [DEBUG] [.jetty.server.handler.ContextHandler] - scope null||/rest/things/homematic:bridge:9723d911/config @ HttpServiceContext{httpContext=DefaultHttpContext [bundle=org.openhab.ui.habpanel_2.1.0 [179], contextID=default]}
2017-11-17 19:22:24.846 [DEBUG] [.jetty.server.handler.ContextHandler] - scope null||/rest/things/homematic:bridge:9723d911/config @ HttpServiceContext{httpContext=DefaultHttpContext [bundle=org.openhab.core_2.1.0 [166], contextID=default]}
2017-11-17 19:22:24.846 [DEBUG] [org.eclipse.jetty.server.Server ] - RESPONSE /rest/things/homematic:bridge:9723d911/config 500 handled=true
2017-11-17 19:22:24.847 [DEBUG] [clipse.jetty.server.HttpChannelState] - HttpChannelState@2e9c9b58{s=DISPATCHED i=true a=null} unhandle DISPATCHED
2017-11-17 19:22:24.847 [DEBUG] [org.eclipse.jetty.http.HttpParser ] - reset HttpParser{s=END,235 of 235}
2017-11-17 19:22:24.847 [DEBUG] [org.eclipse.jetty.http.HttpParser ] - END --> START
Anybody know what the problem might be?
