Homematic - CCU2 2.27.8 - Inbox Empty
i have a CCU 2 with the Firmware 2.27.8 and the Firewall Settings is “Vollzugriff”. After Install the Binding in Openhab2, i have the follow errows:
2017-06-24 18:04:52.436 [ERROR] [very.HomematicDeviceDiscoveryService] -
java.lang.NullPointerException
at org.openhab.binding.homematic.internal.misc.MiscUtils.validateCharacters(MiscUtils.java:26)[199:org.openhab.binding.homematic:2.0.0]
at org.openhab.binding.homematic.internal.model.HmDevice.setType(HmDevice.java:94)[199:org.openhab.binding.homematic:2.0.0]
at org.openhab.binding.homematic.internal.communicator.parser.ListDevicesParser.parse(ListDevicesParser.java:52)[199:org.openhab.binding.homematic:2.0.0]
at org.openhab.binding.homematic.internal.communicator.client.RpcClient.listDevices(RpcClient.java:137)[199:org.openhab.binding.homematic:2.0.0]
at org.openhab.binding.homematic.internal.communicator.AbstractHomematicGateway.getDeviceDescriptions(AbstractHomematicGateway.java:418)[199:org.openhab.binding.homematic:2.0.0]
at org.openhab.binding.homematic.internal.communicator.AbstractHomematicGateway.loadAllDeviceMetadata(AbstractHomematicGateway.java:358)[199:org.openhab.binding.homematic:2.0.0]
at org.openhab.binding.homematic.discovery.HomematicDeviceDiscoveryService$1.run(HomematicDeviceDiscoveryService.java:108)[199:org.openhab.binding.homematic:2.0.0]
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511)[:1.8.0_131]
at java.util.concurrent.FutureTask.run(FutureTask.java:266)[:1.8.0_131]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(ScheduledThreadPoolExecutor.java:180)[:1.8.0_131]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:293)[:1.8.0_131]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)[:1.8.0_131]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)[:1.8.0_131]
at java.lang.Thread.run(Thread.java:748)[:1.8.0_131]
2017-06-24 18:04:52.649 [ERROR] [very.HomematicDeviceDiscoveryService] -
The Binding is Online but the Inbox is empty. Have anybody a idea?
TEST: Downgrade to 2.25.15 --> WORKS!
This is strange. I am using the same version of the binding together with this CCU firmware version without any problems.
You could try to install the latest Snapshot version of the Homematic binding, because there have been quite a lot changes since version 2.0.
If this version has the same problem you could enable the DEBUG log mode to get more information about the data received from the CCU.
Yes, i install the new Binding over the Website or can i install a Binding
other?
I testing this with the Debug Mode.
Its very strange.
Martin Herbst bot@community.openhab.org schrieb am Sa. 24. Juni 2017 um
20:40:
You can find a detailed description here: Frequently Asked Questions (FAQs)
I install the last snapshot version via
echo ‘deb https://openhab.jfrog.io/openhab/openhab-linuxpkg unstable main’ | sudo tee /etc/apt/sources.list.d/openhab2.list
and now works fine. Thanks for your Support =)
