Hey there,
I am using OpanHab 3.0.2 and added the add on for Homematic CCU.
So far it worked nicely and I was able to add my things to the model.
However I have some trouble with the dimmer thing.
The UI elements under the locations tab does show the kitchen and its light (Homematic dimmer) but its slider does only have a range from 0 to 1.
As I can see the light does turn on a little bit. The range of the slider should be 0 to 100.
I read about a current issue and had a look at the binding version. So I had 3.0.2 of the org.openhab.binding.homematic binding. (Yes the same version like open hab itself)
I thought it might help to install the latest unstable version of that binding and therefore did the following:
sudo systemctl stop openhab.service
cd /usr/share/openhab/addons/
ls
rm openhab-addons-3.0.2.kar
wget https://github.com/MHerbst/openhab-addons-test/raw/master/org.openhab.binding.homematic-3.1.0-SNAPSHOT.jar
ls
sudo openhab-cli clean-cache
sudo systemctl start openhab.service
Nevertheless short after restart is completed, I am able to use 0 to 100 at the slider, but it takes just a few seconds and the slider is back to a 0 to 1 range until I redo that procedure.
Does anyone have an idea what I can do to fix that?
I further don’t get the bundle:list:
openhab> bundle:list -s | grep homem
208 │ Installed │ 80 │ 3.1.0.202104241831 │ org.openhab.binding.homematic
222 │ Active │ 80 │ 3.0.2 │ org.openhab.binding.homematic
Why is 3.1.0 installed but 3.0.2 used?
