Hello!
I have about 20 homematic RF devices - all of them publish updates to openhab.
Homematic IP devices (Motion Sensor) are not published to openhab. Please check this out:
[root@col 0 openhab]# ls -la addons/homema
-rw-r–r-- 1 root root 6650 Aug 7 19:04 addons/org.openhab.action.homematic-1.9.0-SNAPSHOT.jar
-rw-r–r-- 1 root root 148324 Aug 7 19:05 addons/org.openhab.binding.homematic-1.9.0-SNAPSHOT.jar
[root@col 0 logs]# grep 000915698D6139 homematic.log |grep MOTION
2016-08-08 13:29:47.779 [DEBUG] [omematicGenericBindingProvider:64 ]- Adding item Pir_EG_Eingang with DatapointConfig[address=000915698D6139,channel=1,parameter=MOTION]
2016-08-08 13:29:57.951 [DEBUG] [.h.i.c.s.AbstractTypeConverter:105 ]- Converting (Boolean) value ‘false’ with OnOffTypeConverter for HmDatapoint[address=000915698D6139,channel=1,parameter=MOTION]
2016-08-08 14:50:24.625 [DEBUG] [omematicGenericBindingProvider:64 ]- Adding item Pir_EG_Eingang with DatapointConfig[address=000915698D6139,channel=1,parameter=MOTION]
2016-08-08 14:50:27.664 [DEBUG] [.h.i.c.s.AbstractTypeConverter:105 ]- Converting (Boolean) value ‘false’ with OnOffTypeConverter for HmDatapoint[address=000915698D6139,channel=1,parameter=MOTION]
2016-08-09 08:28:43.763 [DEBUG] [omematicGenericBindingProvider:64 ]- Adding item Pir_EG_Eingang with DatapointConfig[address=000915698D6139,channel=1,parameter=MOTION]
2016-08-09 08:28:53.310 [DEBUG] [.h.i.c.s.AbstractTypeConverter:105 ]- Converting (Boolean) value ‘false’ with OnOffTypeConverter for HmDatapoint[address=000915698D6139,channel=1,parameter=MOTION]
[root@col 0 logs]#
homematic ccu2 (firmware 2.21.10):
[root@main 0 ~]# grep 000915698D6139 /var/log/homematic.log |grep “MOTION"=” |grep true
Aug 9 16:14:13 homematic ReGaHss: Info: XmlRpcMethodEvent::execute: Event=“000915698D6139:1”.“MOTION”=true [../Platform/DOM/iseXmlRpc.cpp (344)]
Aug 9 16:14:28 homematic ReGaHss: Info: XmlRpcMethodEvent::execute: Event=“000915698D6139:1”.“MOTION”=true [../Platform/DOM/iseXmlRpc.cpp (344)]
Aug 9 16:15:18 homematic ReGaHss: Info: XmlRpcMethodEvent::execute: Event=“000915698D6139:1”.“MOTION”=true [../Platform/DOM/iseXmlRpc.cpp (344)]
Aug 9 16:15:33 homematic ReGaHss: Info: XmlRpcMethodEvent::execute: Event=“000915698D6139:1”.“MOTION”=true [../Platform/DOM/iseXmlRpc.cpp (344)]
Aug 9 16:15:48 homematic ReGaHss: Info: XmlRpcMethodEvent::execute: Event=“000915698D6139:1”.“MOTION”=true [../Platform/DOM/iseXmlRpc.cpp (344)]
Aug 9 16:17:35 homematic ReGaHss: Info: XmlRpcMethodEvent::execute: Event=“000915698D6139:1”.“MOTION”=true [../Platform/DOM/iseXmlRpc.cpp (344)]
Aug 9 16:17:51 homematic ReGaHss: Info: XmlRpcMethodEvent::execute: Event=“000915698D6139:1”.“MOTION”=true [../Platform/DOM/iseXmlRpc.cpp (344)]
Aug 9 16:18:13 homematic ReGaHss: Info: XmlRpcMethodEvent::execute: Event=“000915698D6139:1”.“MOTION”=true [../Platform/DOM/iseXmlRpc.cpp (344)]
Aug 9 16:18:28 homematic ReGaHss: Info: XmlRpcMethodEvent::execute: Event=“000915698D6139:1”.“MOTION”=true [../Platform/DOM/iseXmlRpc.cpp (344)]
Aug 9 16:18:45 homematic ReGaHss: Info: XmlRpcMethodEvent::execute: Event=“000915698D6139:1”.“MOTION”=true [../Platform/DOM/iseXmlRpc.cpp (344)]
Aug 9 16:20:31 homematic ReGaHss: Info: XmlRpcMethodEvent::execute: Event=“000915698D6139:1”.“MOTION”=true [../Platform/DOM/iseXmlRpc.cpp (344)]
Aug 9 16:20:51 homematic ReGaHss: Info: XmlRpcMethodEvent::execute: Event=“000915698D6139:1”.“MOTION”=true [../Platform/DOM/iseXmlRpc.cpp (344)]
Aug 9 16:21:21 homematic ReGaHss: Info: XmlRpcMethodEvent::execute: Event=“000915698D6139:1”.“MOTION”=true [../Platform/DOM/iseXmlRpc.cpp (344)]
Aug 9 16:21:35 homematic ReGaHss: Info: XmlRpcMethodEvent::execute: Event=“000915698D6139:1”.“MOTION”=true [../Platform/DOM/iseXmlRpc.cpp (344)]
Aug 9 16:21:53 homematic ReGaHss: Info: XmlRpcMethodEvent::execute: Event=“000915698D6139:1”.“MOTION”=true [../Platform/DOM/iseXmlRpc.cpp (344)]
Aug 9 16:22:08 homematic ReGaHss: Info: XmlRpcMethodEvent::execute: Event=“000915698D6139:1”.“MOTION”=true [../Platform/DOM/iseXmlRpc.cpp (344)]
Aug 9 16:22:24 homematic ReGaHss: Info: XmlRpcMethodEvent::execute: Event=“000915698D6139:1”.“MOTION”=true [../Platform/DOM/iseXmlRpc.cpp (344)]
Aug 9 16:22:39 homematic ReGaHss: Info: XmlRpcMethodEvent::execute: Event=“000915698D6139:1”.“MOTION”=true [../Platform/DOM/iseXmlRpc.cpp (344)]
Aug 9 16:22:53 homematic ReGaHss: Info: XmlRpcMethodEvent::execute: Event=“000915698D6139:1”.“MOTION”=true [../Platform/DOM/iseXmlRpc.cpp (344)]
Aug 9 16:23:08 homematic ReGaHss: Info: XmlRpcMethodEvent::execute: Event=“000915698D6139:1”.“MOTION”=true [../Platform/DOM/iseXmlRpc.cpp (344)]
Aug 9 17:07:19 homematic ReGaHss: Info: XmlRpcMethodEvent::execute: Event=“000915698D6139:1”.“MOTION”=true [../Platform/DOM/iseXmlRpc.cpp (344)]
Aug 9 17:07:35 homematic ReGaHss: Info: XmlRpcMethodEvent::execute: Event=“000915698D6139:1”.“MOTION”=true [../Platform/DOM/iseXmlRpc.cpp (344)]
Aug 9 17:07:49 homematic ReGaHss: Info: XmlRpcMethodEvent::execute: Event=“000915698D6139:1”.“MOTION”=true [../Platform/DOM/iseXmlRpc.cpp (344)]
Any idea why I don’t see Homematic IP motion events?
Thanks,
Peter
