I am just struggeling a bit to get my latest HMIP-eTRV radiator devices running in oh.
Looks like they data points are pretty different:
@ptweety
Found your post in homematic forum (see below).
That seems to be an excellent example howto setup eTRV
Would be great if you could share also the other files, e.g. rules, etc.
Group gRoomName_gHeating "Thermostat" <radiator> (gRoomName,gHeating)
Number Room_SET_POINT_MODE "Modus [MAP(HMIP-eTRV.map):%s]" <temperature> (gRoomName_gHeating) {channel="homematic:HmIP-eTRV:ccu:000A1709xxxxxx:1#SET_POINT_MODE"}
Number Room_CONTROL_MODE "Kontroll-Modus [MAP(HMIP-eTRV.map):%s]" <temperature> (gRoomName_gHeating) {channel="homematic:HmIP-eTRV:ccu:000A1709xxxxxx:1#CONTROL_MODE"}
Number Room_ACTUAL_TEMPERATURE "Ist-Temperatur [%.1f °C]" <temperature> (gRoomName_gHeating,gHeatAct) {channel="homematic:HmIP-eTRV:ccu:000A1709xxxxxx:1#ACTUAL_TEMPERATURE"}
Number Room_SET_POINT_TEMPERATURE "Soll-Temperatur [%.1f °C]" <temperature> (gRoomName_gHeating,gHeatSet) {channel="homematic:HmIP-eTRV:ccu:000A1709xxxxxx:1#SET_POINT_TEMPERATURE"}
Dimmer Room_LEVEL "Ventil-Öffnung [%d %%]" <heating> (gRoomName_gHeating,gHeatValve) {channel="homematic:HmIP-eTRV:ccu:000A1709xxxxxx:1#LEVEL"}
Switch Room_BOOST_MODE "Boost" <heating> (gRoomName_gHeating,gHeatBoost) {channel="homematic:HmIP-eTRV:ccu:000A1709xxxxxx:1#BOOST_MODE"}
Number Room_ACTIVE_PROFILE "Aktives Wochenprofil [%d]" <calendar> (gRoomName_gHeating,gHeatProfil) {channel="homematic:HmIP-eTRV:ccu:000A1709xxxxxx:1#ACTIVE_PROFILE"}
Number Room_RSSI_DEVICE "Signalstärke [%d dBm]" <signal> (gRoomName_gHeating,W,gRSSI) {channel="homematic:HmIP-eTRV:ccu:000A1709xxxxxx:1#RSSI_DEVICE"}
Number Room_OPERATING_VOLTAGE "Betriebsspannung [%.1f V]" <battery> (gRoomName_gHeating,W,gVoltage) {channel="homematic:HmIP-eTRV:ccu:000A1709xxxxxx:0#OPERATING_VOLTAGE"}
Switch Room_LOW_BAT "Batterie schwach" <battery> (gRoomName_gHeating,W,gBattery) {channel="homematic:HmIP-eTRV:ccu:000A1709xxxxxx:0#LOW_BAT"}
Switch Room_FROST_PROTECTION "Frostschutz" <climate> (gRoomName_gHeating) {channel="homematic:HmIP-eTRV:ccu:000A1709xxxxxx:0#FROST_PROTECTION"}
String Room_WINDOW_STATE "Fenster [MAP(HMIP-eTRV.map):%s]" <contact> (gRoomName_gHeating) {channel="homematic:HmIP-eTRV:ccu:000A1709xxxxxx:1#WINDOW_STATE"}
Switch Room_PARTY_MODE "Party-Modus" <temperature> (gRoomName_gHeating) {channel="homematic:HmIP-eTRV:ccu:000A1709xxxxxx:1#PARTY_MODE"}
Number Room_PARTY_SET_POINT_TEMPERATURE "Party-Temperatur [%.1f °C]" <temperature> (gRoomName_gHeating) {channel="homematic:HmIP-eTRV:ccu:000A1709xxxxxx:1#PARTY_SET_POINT_TEMPERATURE"}
DateTime Room_PARTY_TIME_START "Party-Start [%1ta %1$tR]" <clock> (gRoomName_gHeating) {channel="homematic:HmIP-eTRV:ccu:000A1709xxxxxx:1#PARTY_TIME_START"}
DateTime Room_PARTY_TIME_END "Party-Ende [%1ta %1$tR]" <clock> (gRoomName_gHeating) {channel="homematic:HmIP-eTRV:ccu:000A1709xxxxxx:1#PARTY_TIME_END"}
String gRoomName_gHeating_summary "Badezimmer [%s]" <radiator>
// HMIP-eTRV Heizkörperthermostat
// 1#WINDOW_STATE
CLOSED=Verschlossen
OPEN=Offen
// 1#SET_POINT_MODE
-1=-Unbestimmt-
0=Automatik
1=Manuell
2=Urlaub
3=Boost
// 1#CONTROL_MODE
AUTO-MODE=Automatik
MANU-MODE=Manuelle Schaltung
PARTY-MODE=Party-Modus
BOOST-MODE=Boost
// UNSET
NULL=unbekannt ⁉
-=unbekannt ⁉
