Using openhab 3.3 stable I got the following error messages. Any hint what this means / how to fix.
“ABORT_EVENT_SENDING_CHANNELS” does not tell me anything.
2022-11-11 14:36:41.350 [WARN ] [ternal.handler.HomematicThingHandler] - Value for datapoint HmDatapoint[name=ABORT_EVENT_SENDING_CHANNELS,value=8,defaultValue=8,type=INTEGER,minValue=0,maxValue=4,options=null,readOnly=false,readable=true,unit=null,description=ABORT_EVENT_SENDING_CHANNELS,info=null,paramsetType=MASTER,virtual=false,trigger=false] is outside of valid range, using default value for config.
2022-11-11 14:36:41.367 [WARN ] [ternal.handler.HomematicThingHandler] - Value for datapoint HmDatapoint[name=ABORT_EVENT_SENDING_CHANNELS,value=16,defaultValue=16,type=INTEGER,minValue=0,maxValue=4,options=null,readOnly=false,readable=true,unit=null,description=ABORT_EVENT_SENDING_CHANNELS,info=null,paramsetType=MASTER,virtual=false,trigger=false] is outside of valid range, using default value for config.
2022-11-11 14:36:41.383 [WARN ] [ternal.handler.HomematicThingHandler] - Value for datapoint HmDatapoint[name=ABORT_EVENT_SENDING_CHANNELS,value=32,defaultValue=32,type=INTEGER,minValue=0,maxValue=4,options=null,readOnly=false,readable=true,unit=null,description=ABORT_EVENT_SENDING_CHANNELS,info=null,paramsetType=MASTER,virtual=false,trigger=false] is outside of valid range, using default value for config.
