I tried to integrate the HMIP-WRC6 via the CCU.
I only ever seem to receive the UNREACH event whenever I push a button:
10:03:51.788 [TRACE] [rnal.communicator.server.XmlRpcServer] - Server parsed XmlRpcMessage:
system.multicall()
methodName=event
params=
HMIP-09319ca3
000B57099511A9:0
UNREACH
false
methodName=event
params=
HMIP-09319ca3
000B57099511A9:0
RSSI_DEVICE
-69
10:03:51.835 [DEBUG] [communicator.AbstractHomematicGateway] - Received new (Boolean) value 'false' for '000B57099511A9:0#UNREACH' from gateway with id '09319ca3'
10:03:51.855 [DEBUG] [communicator.AbstractHomematicGateway] - Received new (Integer) value '-69' for '000B57099511A9:0#RSSI_DEVICE' from gateway with id '09319ca3'
10:03:51.875 [TRACE] [rnal.communicator.server.XmlRpcServer] - Server XmlRpcResponse:
<?xml version="1.0" encoding="ISO-8859-1"?>
<methodResponse><params><param><value><array><data><value>event</value></data></array></value></param></params></methodResponse>
Native Homematic devices are sent and received correctly.
I already created the file services/homematic.cfg containing:
homematicIP.enabled = true
After trying for 2 days now, I seem to be out of ideas on how to solve this…
