I noticed a very weird behaviour during the initalisation of the bridge, when adding a homematic ccu3 to openhab via the homematic binding.
I was running openhab successfully for nearly a year on a raspberry pi on docker. I upgraded my single raspberry now to a stack of raspberry pi and also changed my deployment from a single docker instance to a docker swarm. As long as openhab was my only stack on docker, everything worked like a charm.
Yesterday, I added a new deployment in my docker stack and after a restart of openhab, suddenly the homematic ccu gateway could not be reached any more. The error shown was Jetty start failed.
After increasing the log level with log:set DEBUG org.openhab.binding.homematic
the java stack trace revealed the true error:
2020-10-19 13:57:44.486 [DEBUG] [ernal.handler.HomematicBridgeHandler] - Homematic bridge was set to OFFLINE-COMMUNICATION_ERROR due to the following exception: Jetty start failed
java.io.IOException: Jetty start failed
at org.openhab.binding.homematic.internal.communicator.server.XmlRpcServer.start(XmlRpcServer.java:92) ~[?:?]
at org.openhab.binding.homematic.internal.communicator.AbstractHomematicGateway.startServers(AbstractHomematicGateway.java:254) ~[?:?]
at org.openhab.binding.homematic.internal.communicator.AbstractHomematicGateway.initialize(AbstractHomematicGateway.java:192) ~[?:?]
at org.openhab.binding.homematic.internal.handler.HomematicBridgeHandler.initializeInternal(HomematicBridgeHandler.java:111) ~[?:?]
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511) [?:1.8.0_265]
at java.util.concurrent.FutureTask.run(FutureTask.java:266) [?:1.8.0_265]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(ScheduledThreadPoolExecutor.java:180) [?:1.8.0_265]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:293) [?:1.8.0_265]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) [?:1.8.0_265]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) [?:1.8.0_265]
at java.lang.Thread.run(Thread.java:748) [?:1.8.0_265]
Caused by: java.io.IOException: Failed to bind to 15ac3e7b197e/10.0.5.5:9125
at org.eclipse.jetty.server.ServerConnector.openAcceptChannel(ServerConnector.java:346) ~[bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.ServerConnector.open(ServerConnector.java:307) ~[bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.AbstractNetworkConnector.doStart(AbstractNetworkConnector.java:80) ~[bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.ServerConnector.doStart(ServerConnector.java:231) ~[bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.util.component.AbstractLifeCycle.start(AbstractLifeCycle.java:72) ~[bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.Server.doStart(Server.java:385) ~[bundleFile:9.4.20.v20190813]
at org.openhab.binding.homematic.internal.communicator.server.XmlRpcServer.start(XmlRpcServer.java:87) ~[?:?]
... 10 more
Caused by: java.net.BindException: Cannot assign requested address
at sun.nio.ch.Net.bind0(Native Method) ~[?:1.8.0_265]
at sun.nio.ch.Net.bind(Net.java:433) ~[?:1.8.0_265]
at sun.nio.ch.Net.bind(Net.java:425) ~[?:1.8.0_265]
at sun.nio.ch.ServerSocketChannelImpl.bind(ServerSocketChannelImpl.java:220) ~[?:1.8.0_265]
at sun.nio.ch.ServerSocketAdaptor.bind(ServerSocketAdaptor.java:85) ~[?:1.8.0_265]
at org.eclipse.jetty.server.ServerConnector.openAcceptChannel(ServerConnector.java:342) ~[bundleFile:9.4.20.v20190813]
... 10 more
The line Caused by: java.io.IOException: Failed to bind to 15ac3e7b197e/10.0.5.5:9125
catched my attention because that ip address is not even available in the openhab container.
openhab$ ip -br addr
lo UNKNOWN 127.0.0.1/8
eth0@if148 UP 10.0.0.19/24
eth2@if150 UP 172.18.0.3/16
eth1@if152 UP 10.0.4.11/24
The ip address 10.0.5.5 belongs to a container running on another node.
My openhab bridge configuration is the following: HomematicConfig[gatewayAddress=192.168.123.128,callbackHost=192.168.123.142,bindAddress=0.0.0.0,xmlCallbackPort=9125,binCallbackPort=9126,gatewayType=auto,rfPort=2001,wiredPort=2000,hmIpPort=2010,cuxdPort=8701,groupPort=9292,timeout=15,discoveryTimeToLive=-1,installModeDuration=60,socketMaxAlive=900]
Does anyone know how java/jetty was able to discover the 10.0.5.5 address and how it is possible to prevent this from happening?
Using 10.0.0.19 as callback address is not possible, since the ip address changes on every creation of the openhab container.
