Hey guys,
I know that the second error is of course because of the first one. I have a CCU2 and CCU3 so both are offline. And both are working as a bridge for different HomeMatic devices. So the Offline Bridge Error is clear. Insinde PaperUI I can read on both Things for the CCU`s that the connection is lost.
OpenHAB is in the version 2.5.12-1 and the OpenHAB Addons also. I have updated the firmware of both CCU`s. So maybe the solution is quite easy and I should downgrade it. But I was wondering because yesterday the CCU3 worked for a few minutes and then again was offline. The current firmware version of the CCU3 is 3.57.5 and the CCU2 uses 2.57.5.
CCU2 configuration:
Firewall:
Homematic XML-RPC API: Full Access
Remote Homematic-Script API: Restricted
IP addresses who should have access are 192.168.0.1; 192.168.0.0/16 because this would make it accessable in a upper network.
CCU2 thing configuration:
Gateway Address: 192.168.0.12
Gateway Type: CCU
Callback Network Address: 192.168.0.5
Install Mode Duration: 60
Timeout: 15
Discovery Time to Live: -1
Socket MaxAlive: 900
RF Port: 2001
Wired Port: 2000
HMIP Port: 2010
CUxD Port: 8701
Group Port: 9292
CCU3 configuration:
Firewall:
Firewall policy: Ports open
Mediola access: No access
CCU3 thing configuration:
Gateway Address: 192.168.0.50
Gateway Type: CCU
Timeout: 15
RF Port: 2001
Wired Port: 2000
HMIP Port: 2010
CUxD Port: 8701
Group Port: 9292
I mean, the update does not change the configuration. Therefore, it is perhaps more the compatibility between the binding/addon and the firmware.
For the CCU2 I get as example:
09:26:27.128 [INFO ] [nternal.communicator.client.RpcClient] - Interface 'WIRED' on gateway 'MEQ0461285' not available, disabling support
09:26:27.175 [INFO ] [nternal.communicator.client.RpcClient] - Interface 'CUXD' on gateway 'MEQ0461285' not available, disabling support
09:26:27.254 [INFO ] [communicator.AbstractHomematicGateway] - HmGatewayInfo[id=CCU,type=CCU2,firmware=2.8.6,address=MEQ0461285,rf=true,wired=false,hmip=true,cuxd=false,group=true]
Does the last line mean that it is waiting for firmware 2.8.6 to be installed or does it mean that I could only install this firmware, so that mine is too new? Or in other words, do I need to configure something else so that it recognises a new firmware version? I do not see where to configure the firmware version number.
Perhaps someone can help me further. Many thanks in advance!
