I managed to setup Openhabian on my Raspi. I installed the demo files
as well and all my things and items were successfully discovered.
Two thermostats (Homematic HM-CC-RT-DN) and one wall thermostat HG_HM_TC_IT_WM_W_EU are in my setup.
To start out I want to keep it extremely simple:
Whenever I change the wall thermostat (which is in manual mode)
the radiator thermostats’ target temperature should be set to
the value of the wall thermostat.
var Number temperature = 0
var Number oldTemperature = 0
rule "woziTemp"
Item homematic_HG_HM_TC_IT_WM_W_EU_HMCFGUSB2_MEQ0869632_2_SET_TEMPERATURE received update
temperature = homematic_HG_HM_TC_IT_WM_W_EU_HMCFGUSB2_MEQ0869632_2_SET_TEMPERATURE.state
logInfo("wozi", "" + oldTemperature + " - " + temperature)
if (temperature != oldTemperature) {
oldTemperature = temperature
// Regal
homematic_HG_HM_CC_RT_DN_HMCFGUSB2_LEQxxxxxx_4_SET_TEMPERATURE.state = temperature
// Couch
homematic_HG_HM_CC_RT_DN_HMCFGUSB2_MEQxxxxxx_4_SET_TEMPERATURE.state = temperature
logInfo("wozi", "Temperature set to " + temperature)
This rule works OK. But what drives me up the wall is that the radiator thermo
stats set themselves back to the previous value after a couple of minutes.
See the log below.
2017-02-18 14:51:54.270 [ItemStateChangedEvent ] - homematic_HG_HM_TC_IT_WM_W_EU_HMCFGUSB2_MEQ0xxxxxx_2_SET_TEMPERATURE changed from 29.00 to 27.50
2017-02-18 14:51:54.302 [ItemStateChangedEvent ] - homematic_HG_HM_CC_RT_DN_HMCFGUSB2_LEQ1xxxxxx_4_SET_TEMPERATURE changed from 22.50 to 27.50
2017-02-18 14:51:54.307 [ItemStateChangedEvent ] - homematic_HG_HM_CC_RT_DN_HMCFGUSB2_MEQ1xxxxxx_4_SET_TEMPERATURE changed from 22.50 to 27.50
2017-02-18 14:52:04.724 [ItemStateChangedEvent ] - homematic_HG_HM_CC_RT_DN_HMCFGUSB2_LEQ1188821_4_SET_TEMPERATURE changed from 27.50 to 22.50
2017-02-18 14:52:12.224 [ItemStateChangedEvent ] - homematic_HG_HM_CC_RT_DN_HMCFGUSB2_MEQ1546967_4_ACTUAL_TEMPERATURE changed from 25.60 to 25.50
2017-02-18 14:52:12.237 [ItemStateChangedEvent ] - homematic_HG_HM_CC_RT_DN_HMCFGUSB2_MEQ1546967_4_SET_TEMPERATURE changed from 27.50 to 22.50
Any idea what I’m doing wrong?
Cheers,
Christian
