I am using homematic wall thermostats to control heating. Setup is armv71, Raspbian GNU/Linux 9 (stretch). This has worked fine for two years. However, at the beginning of this heating period, I cannot set temperatures any more.
- In PaperUI (or my sitemap), I can read the actual temperature
- In PaperUI (or my sitemap), I can set Auto to Manu and vice versa,I can change temperature offset etc.
… only Set_Temperature won’t do.
error.log shows that the temperature has been changed
openhab.log shows
java.lang.IllegalArgumentException: Invalid URI host: null (authority: null)
at org.eclipse.jetty.client.HttpClient.checkHost(HttpClient.java:510) ~[?:?]
at org.eclipse.jetty.client.HttpClient.newHttpRequest(HttpClient.java:495) ~[?:?]
at org.eclipse.jetty.client.HttpClient.newRequest(HttpClient.java:453) ~[?:?]
at org.eclipse.jetty.client.HttpClient.newRequest(HttpClient.java:442) ~[?:?]
at org.eclipse.smarthome.io.net.http.HttpUtil.executeUrlAndGetReponse(HttpUtil.java:212) ~[?:?]
at org.eclipse.smarthome.io.net.http.HttpUtil.downloadData(HttpUtil.java:438) ~[?:?]
at org.eclipse.smarthome.io.net.http.HttpUtil.downloadData(HttpUtil.java:417) ~[?:?]
at org.openhab.binding.miio.internal.cloud.CloudConnector.getMap(CloudConnector.java:141) ~[?:?]
at org.openhab.binding.miio.internal.handler.MiIoVacuumHandler.getMap(MiIoVacuumHandler.java:585) ~[?:?]
at org.openhab.binding.miio.internal.handler.MiIoVacuumHandler.lambda$7(MiIoVacuumHandler.java:521) ~[?:?]
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511) ~[?:1.8.0_265]
at java.util.concurrent.FutureTask.run(FutureTask.java:266) ~[?:1.8.0_265]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(ScheduledThreadPoolExecutor.java:180) ~[?:1.8.0_265]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:293) ~[?:1.8.0_265]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) [?:1.8.0_265]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) [?:1.8.0_265]
at java.lang.Thread.run(Thread.java:748) [?:1.8.0_265]
I have no clue, who is the baddy here.
Any help very welcome!
Many thanks,
Nikolaus
