EDIT
Found out, it was one FROLL actor mailfunctioning, which caused so much trouble. When I commented the actor out, the rest of the actors in the items-list worked as it should.
original message:
Hi, did I missed something with the update to 2.5.12 for the homematic addon? All my Rollershutters are not working anymore. In the sitemap my Rollershutter group is empty and Default item=rollershutter is not showing.
my items:
Rollershutter SuedterasseMarkise_Level "Level [%.0f %%]" <rollershutter> (HmIpBrollProxy) {Proxy='' [LevelItem="SuedterasseMarkise_Level_Actuator"]}
Rollershutter SuedterasseMarkise_Level_Actuator "Markise Südterasse [MAP(broll.map):%s]" {channel="homematic:HmIP-BROLL:XXXX:YYYYY:4#LEVEL"}
Rollershutter SuedterasseMarkise_Level_Status (HmIpBrollLevel) {channel="homematic:HmIP-BROLL:XXXX:YYYY:3#LEVEL", Proxy='' [ProxyItem="SuedterasseMarkise_Level"]}
broll.map:
O=100%
100=0%
sitemap:
Default item=SuedterasseMarkise_Level_Actuator label="Markise Südterasse" icon="terrace"
Group item=gRollo label="Rollos" icon="blinds"
I“m working with this rules:
from core.rules import rule
from core.triggers import when
from core.metadata import get_key_value
from core.utils import getItemValue
@rule('Proxying roller shutter commands', description = 'Pass proxy item commands to channel 4')
@when('Member of HmIpBrollProxy received command')
def send_command(event):
level_item_name = str(get_key_value(event.itemName,'Proxy','LevelItem'))
events.sendCommand(level_item_name, str(event.itemCommand))
@rule('Proxying HmIP-BROLL level', description = 'Send level channel 3 to Proxy item')
@when('Member of HmIpBrollLevel received update')
def main_update(event):
proxy_item_name = str(get_key_value(event.itemName,'Proxy','ProxyItem'))
events.postUpdate(ir.getItem(proxy_item_name), QuantityType(str(event.itemState)))
Thanks a lot for every hint.
