I finally made it to get my thermostats running smooth in openHab, but they are still not accessible in Google Home.
They are discovered by the Google Home app and I can assign them to the different rooms, but when I oen a Thermostat controll it just says “Offline”
What point do I miss?
Items:
Group gAZ_thermostat "Heizung" ["Thermostat"]
Number AZ_thermostat_Mode "Thermostat Mode" (gAZ_thermostat) ["homekit:HeatingCoolingMode"]
Number AZ_4ACTUALTEMPERATURE "aktuelle Temperatur" <temperature> (gAZ_thermostat) ["CurrentTemperature"] {channel="homematic:HM-CC-RT-DN:3014F711A061A7D8A9AB3FE8:PEQ1312969:4#ACTUAL_TEMPERATURE"}
Number AZ_4SETTEMPERATURE "soll Temperatur" <temperature> (gAZ_thermostat) ["TargetTemperature"] {channel="homematic:HM-CC-RT-DN:3014F711A061A7D8A9AB3FE8:PEQ1312969:4#SET_TEMPERATURE"}
Switch AZ_4BOOSTMODE "Boost mode" <temperature> {channel="homematic:HM-CC-RT-DN:3014F711A061A7D8A9AB3FE8:PEQ1312969:4#BOOST_MODE"}
String AZ_4CONTROLMODE "Control mode" <settings> {channel="homematic:HM-CC-RT-DN:3014F711A061A7D8A9AB3FE8:PEQ1312969:4#CONTROL_MODE"}
Switch AZ_4AUTOMODE "Auto mode" <settings> {channel="homematic:HM-CC-RT-DN:3014F711A061A7D8A9AB3FE8:PEQ1312969:4#AUTO_MODE"}
Number AZ_4MANUMODE "Manu mode" <settings> {channel="homematic:HM-CC-RT-DN:3014F711A061A7D8A9AB3FE8:PEQ1312969:4#MANU_MODE"}
Number:ElectricPotential AZ_4BATTERYSTATE "Battery Status" <batterylevel> {channel="homematic:HM-CC-RT-DN:3014F711A061A7D8A9AB3FE8:PEQ1312969:4#BATTERY_STATE"}
Number AZ_4VALVESTATE "Ventilstellung [%.0f %%]" <pressure> {channel="homematic:HM-CC-RT-DN:3014F711A061A7D8A9AB3FE8:PEQ1312969:4#VALVE_STATE"}
Number AZ_4BOOSTSTATE "noch im Boostmodus [%.0f Min]" <time> {channel="homematic:HM-CC-RT-DN:3014F711A061A7D8A9AB3FE8:PEQ1312969:4#BOOST_STATE"}
Sitemap:
Text label="Heizung EZ" {
Default item=EZ_4ACTUALTEMPERATURE
Setpoint item=EZ_4SETTEMPERATURE minValue=15 maxValue=30 step=1
Selection item=EZ_thermostat_Mode mappings=[1="Automatic", 2="Manual", 3="Boost"]
Default item=EZ_4BATTERYSTATE
Default item=EZ_4VALVESTATE
Default item=EZ_4BOOSTSTATE visibility=[EZ_4CONTROLMODE == "BOOST-MODE"]
Rules:
rule "AZ_Mode Switch"
Item AZ_thermostat_Mode changed
if (AZ_thermostat_Mode.state == 1){
AZ_4AUTOMODE.sendCommand(ON)
} else if (AZ_thermostat_Mode.state == 2){
AZ_4MANUMODE.sendCommand(Target_Temperature.state as Number)
} else if (AZ_thermostat_Mode.state == 3){
AZ_4BOOSTMODE.sendCommand(ON)
rule "AZ_Sync thermostat mode"
Item AZ_4CONTROLMODE changed
if (AZ_4CONTROLMODE.state.toString == "MANU-MODE"){
AZ_thermostat_Mode.sendCommand(2)
}else if(AZ_4CONTROLMODE.state.toString == "AUTO-MODE"){
AZ_thermostat_Mode.sendCommand(1)
} else if (AZ_4CONTROLMODE.state.toString =="BOOST-MODE"){
AZ_thermostat_Mode.sendCommand(3)
cheers
Sascha
