Hey guys,
I really need your help. Since 1 week I am playing around to get my homematic thermostats hm-cc-rt-dn working again. As you know since upgrade to 2.4 there is issue with “Can’t convert type QuantityType with value”. I was reading all posts on this topic, but workaround deleting thing and adding again is not working for me. I have changed the rules to use Quantity type conversion. So I guess there is something else wrong.
Strange is, that also my Mode changing is not working.
The log outcome:
2019-01-16 09:34:07.059 [WARN ] [ematic.handler.HomematicThingHandler] - Can’t convert type QuantityType with value ‘22.5 C’ to FLOAT value with DecimalTypeConverter for ‘LEQ0781024:4#SET_TEMPERATURE’, please check the item type and the commands in your scripts
rule "Thermostat mode Kidroom room"
Item Kidroom_Control_Mode_openHAB changed
logDebug("homematic", "Mode switcher rule of Kidroom room executed with control mode '{}'",
Kidroom_Control_Mode_openHAB.state.toString)
if("MANU-MODE".equals(Kidroom_Control_Mode_openHAB.state.toString)) {
Kidroom_Control_Mode_Manu.sendCommand(Heating_kidroom_SET_TEMP.state as QuantityType<Number>).doubleValue
logInfo("homematic", "Switched Kidroom room to MANU_MODE with value {}",
} else if("AUTO-MODE".equals(Kidroom_Control_Mode_openHAB.state.toString)) {
Kidroom_Control_Mode_Auto.sendCommand(ON)
logInfo("homematic", "Switched Kidroom room to AUTO_MODE")
} else if("BOOST-MODE".equals(Kidroom_Control_Mode_openHAB.state.toString)) {
Kidroom_Control_Mode_Boost.sendCommand(ON)
logInfo("homematic", "Switched Kidroom room to BOOST_MODE")
at org.eclipse.smarthome.binding.homematic.internal.converter.type.QuantityTypeConverter.toBinding(QuantityTypeConverter.java:58) ~[213:org.eclipse.smarthome.binding.homematic:0.10.0.oh240]
at org.eclipse.smarthome.binding.homematic.internal.converter.type.QuantityTypeConverter.toBinding(QuantityTypeConverter.java:1) ~[213:org.eclipse.smarthome.binding.homematic:0.10.0.oh240]
at org.eclipse.smarthome.binding.homematic.internal.converter.type.AbstractTypeConverter.convertToBinding(AbstractTypeConverter.java:102) ~[213:org.eclipse.smarthome.binding.homematic:0.10.0.oh240]
at org.eclipse.smarthome.binding.homematic.handler.HomematicThingHandler.handleCommand(HomematicThingHandler.java:281) [213:org.eclipse.smarthome.binding.homematic:0.10.0.oh240]
at sun.reflect.GeneratedMethodAccessor81.invoke(Unknown Source) ~[?:?]
at org.eclipse.smarthome.core.internal.common.AbstractInvocationHandler.invokeDirect(AbstractInvocationHandler.java:153) [102:org.eclipse.smarthome.core:0.10.0.oh240]
at org.eclipse.smarthome.core.internal.common.InvocationHandlerSync.invoke(InvocationHandlerSync.java:59) [102:org.eclipse.smarthome.core:0.10.0.oh240]
at com.sun.proxy.$Proxy149.handleCommand(Unknown Source) [213:org.eclipse.smarthome.binding.homematic:0.10.0.oh240]
at org.eclipse.smarthome.core.thing.internal.profiles.ProfileCallbackImpl.handleCommand(ProfileCallbackImpl.java:75) [109:org.eclipse.smarthome.core.thing:0.10.0.oh240]
at org.eclipse.smarthome.core.thing.internal.profiles.SystemDefaultProfile.onCommandFromItem(SystemDefaultProfile.java:49) [109:org.eclipse.smarthome.core.thing:0.10.0.oh240]
at sun.reflect.GeneratedMethodAccessor80.invoke(Unknown Source) ~[?:?]
at org.eclipse.smarthome.core.internal.common.Invocation.call(Invocation.java:53) [102:org.eclipse.smarthome.core:0.10.0.oh240]
Hi
I can change temperature now. But unfortunatetly mode switching does not work. I have no idea why. “predicted to become NULL” indicated something is not OK.
Blockquote 2019-01-17 10:16:56.618 [ome.event.ItemCommandEvent] - Item ‘Livingroom_Control_Mode_openHAB’ received command MANU-MODE
2019-01-17 10:16:56.634 [vent.ItemStateChangedEvent] - Livingroom_Control_Mode_openHAB changed from AUTO-MODE to MANU-MODE
2019-01-17 10:16:56.695 [ome.event.ItemCommandEvent] - Item ‘Livingroom_Control_Mode_Manu’ received command 21.0
2019-01-17 10:16:56.702 [INFO ] [pse.smarthome.model.script.homematic] - Switched Living room to MANU_MODE with value 21.0
2019-01-17 10:16:56.702 [nt.ItemStatePredictedEvent] - Livingroom_Control_Mode_Manu predicted to become NULL
This message comes from OH autoupdate. When an Item is sent a command, autoupdate has a guess at what effect that might have on the Item.
In this case a String type item Livingroom_Control_Mode_Manu has been sent the numeric command 21.0 (presumably by some rule we cannot see?)
If you want that command to set the state of the Item, I think you’ll need to send it as a string “21.0” ( .toString is useful)
If you don’t want autoupdate to interfere, you can set it false for that Item.
If you don’t need to send a command at all, just change the state of the Item, use .postUpdate (but I think you’ll still need .toString)
It’s arguable that autoupdate ought to take care of that for you. There might be reasons why it doesn’t.
