Hey guys,
i got my homegear-CUL Thing running. And the thermostats are receiving signals (like the window state) but openhab say offline - communication error. Any help on this issue is appreciated:
19:20:18.013 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'HeizkRperBad_3_Fensterstatus' received command OFF
19:20:18.039 [INFO ] [smarthome.event.ItemStateChangedEvent] - HeizkRperBad_3_Fensterstatus changed from ON to OFF
19:20:23.023 [WARN ] [rnal.common.AbstractInvocationHandler] - Timeout of 5000ms exceeded while calling method 'StateProfile.onCommandFromItem()' on 'org.eclipse.smarthome.core.thing.internal.profiles.SystemDefaultProfile@6f814a'. Thread 'safeCall-11' (330) is in state 'RUNNABLE'
at java.net.SocketInputStream.socketRead0(Native Method)
at java.net.SocketInputStream.socketRead(SocketInputStream.java:116)
at java.net.SocketInputStream.read(SocketInputStream.java:171)
at java.net.SocketInputStream.read(SocketInputStream.java:141)
at org.openhab.binding.homematic.internal.communicator.message.BinRpcMessage.<init>(BinRpcMessage.java:75)
at org.openhab.binding.homematic.internal.communicator.client.BinRpcClient.sendMessage(BinRpcClient.java:77)
at org.openhab.binding.homematic.internal.communicator.client.BinRpcClient.sendMessage(BinRpcClient.java:90)
at org.openhab.binding.homematic.internal.communicator.client.BinRpcClient.sendMessage(BinRpcClient.java:66)
at org.openhab.binding.homematic.internal.communicator.client.RpcClient.setDatapointValue(RpcClient.java:293)
at org.openhab.binding.homematic.internal.communicator.AbstractHomematicGateway$1.execute(AbstractHomematicGateway.java:565)
at org.openhab.binding.homematic.internal.misc.DelayedExecuter.start(DelayedExecuter.java:61)
at org.openhab.binding.homematic.internal.communicator.AbstractHomematicGateway.sendDatapoint(AbstractHomematicGateway.java:544)
at org.openhab.binding.homematic.internal.communicator.AbstractHomematicGateway.sendDatapoint(AbstractHomematicGateway.java:523)
at org.openhab.binding.homematic.handler.HomematicThingHandler.handleCommand(HomematicThingHandler.java:175)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:498)
at org.eclipse.smarthome.core.internal.common.AbstractInvocationHandler.invokeDirect(AbstractInvocationHandler.java:157)
at org.eclipse.smarthome.core.internal.common.InvocationHandlerSync.invoke(InvocationHandlerSync.java:56)
at com.sun.proxy.$Proxy140.handleCommand(Unknown Source)
19:20:23.149 [WARN ] [mematic.handler.HomematicThingHandler] - Device 'MEQ1585016' is OFFLINE, can't send command 'OFF' for channel 'homematic:HG-HM-CC-RT-DN:95567712:MEQ1585016:3#WINDOW_STATE'
19:23:20.708 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'HeizkRperBad_3_Fensterstatus' received command ON
19:23:20.730 [INFO ] [smarthome.event.ItemStateChangedEvent] - HeizkRperBad_3_Fensterstatus changed from OFF to ON
19:23:25.729 [WARN ] [rnal.common.AbstractInvocationHandler] - Timeout of 5000ms exceeded while calling method 'StateProfile.onCommandFromItem()' on 'org.eclipse.smarthome.core.thing.internal.profiles.SystemDefaultProfile@6f814a'. Thread 'safeCall-20' (389) is in state 'RUNNABLE'
19:23:25.857 [WARN ] [mematic.handler.HomematicThingHandler] - Device 'MEQ1585016' is OFFLINE, can't send command 'ON' for channel 'homematic:HG-HM-CC-RT-DN:95567712:MEQ1585016:3#WINDOW_STATE'
19:25:03.289 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'HeizkRperBad_3_Fensterstatus' received command OFF
19:25:03.318 [INFO ] [smarthome.event.ItemStateChangedEvent] - HeizkRperBad_3_Fensterstatus changed from ON to OFF
19:25:04.577 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'HeizkRperBad_3_Fensterstatus' received command ON
19:25:04.592 [INFO ] [smarthome.event.ItemStateChangedEvent] - HeizkRperBad_3_Fensterstatus changed from OFF to ON
19:25:08.302 [WARN ] [rnal.common.AbstractInvocationHandler] - Timeout of 5000ms exceeded while calling method 'StateProfile.onCommandFromItem()' on 'org.eclipse.smarthome.core.thing.internal.profiles.SystemDefaultProfile@6f814a'. Thread 'safeCall-21' (422) is in state 'RUNNABLE'
19:25:08.423 [WARN ] [mematic.handler.HomematicThingHandler] - Device 'MEQ1585016' is OFFLINE, can't send command 'OFF' for channel 'homematic:HG-HM-CC-RT-DN:95567712:MEQ1585016:3#WINDOW_STATE'
19:25:13.436 [WARN ] [rnal.common.AbstractInvocationHandler] - Timeout of 5000ms exceeded while calling method 'StateProfile.onCommandFromItem()' on 'org.eclipse.smarthome.core.thing.internal.profiles.SystemDefaultProfile@6f814a'. Thread 'safeCall-26' (429) is in state 'RUNNABLE'
19:25:13.557 [WARN ] [mematic.handler.HomematicThingHandler] - Device 'MEQ1585016' is OFFLINE, can't send command 'ON' for channel 'homematic:HG-HM-CC-RT-DN:95567712:MEQ1585016:3#WINDOW_STATE'
