I would like to change the configuration of homematic devices with openHab (BasicUI).
An example:
I have a “HM-CC-RT-DN”, in the settings of the web interface the channels are displayed for this “Thing”. In addition, you can also see under the “Code” tab that there are config settings. Can these also be accessed in the same way as the channels?
binding author is for example debmatic?
Because I used to have the same hardware with homegear in operation and was able to read out (much) more channels (eg. for window contact, with the thermostat).
