While integrating a few Homematic-IP Door/Window Contacts via CCU2 with the Homematic Binding (openhab2 latest unstable) I noticed that only the String type seems to be supported on the STATE channel.
Is this the expected behaviour?
openhab> smarthome:items list *XX*
XX_Fenster_StateContactCon (Type=ContactItem, State=NULL, Label=Fenster, Category=contact, Groups=[gWindow])
XX_Fenster_StateContactStr (Type=StringItem, State=NULL, Label=Fenster, Category=contact, Groups=[gWindow])
XX_Fenster_StateContactNum (Type=NumberItem, State=NULL, Label=Fenster, Category=contact, Groups=[gWindow])
XX_Fenster_StateContactSwi (Type=SwitchItem, State=NULL, Label=Fenster, Category=contact, Groups=[gWindow])
XX_Fenster_StateCon (Type=ContactItem, State=NULL, Label=Fenster, Category=contact, Groups=[gWindow])
XX_Fenster_StateStr (Type=StringItem, State=CLOSED, Label=Fenster, Category=contact, Groups=[gWindow])
XX_Fenster_StateNum (Type=NumberItem, State=NULL, Label=Fenster, Category=contact, Groups=[gWindow])
XX_Fenster_StateSwi (Type=SwitchItem, State=NULL, Label=Fenster, Category=contact, Groups=[gWindow])
The items file contains this:
Contact XX_Fenster_StateContactCon "Fenster [MAP(window.map):%s]" <contact> (gWindow) {channel="homematic:HMIP-SWDO:ccu2:0000D569A49B6E:1#STATE_CONTACT"}
String XX_Fenster_StateContactStr "Fenster [MAP(window.map):%s]" <contact> (gWindow) {channel="homematic:HMIP-SWDO:ccu2:0000D569A49B6E:1#STATE_CONTACT"}
Number XX_Fenster_StateContactNum "Fenster [MAP(window.map):%s]" <contact> (gWindow) {channel="homematic:HMIP-SWDO:ccu2:0000D569A49B6E:1#STATE_CONTACT"}
Switch XX_Fenster_StateContactSwi "Fenster [MAP(window.map):%s]" <contact> (gWindow) {channel="homematic:HMIP-SWDO:ccu2:0000D569A49B6E:1#STATE_CONTACT"}
Contact XX_Fenster_StateCon "Fenster [MAP(window.map):%s]" <contact> (gWindow) {channel="homematic:HMIP-SWDO:ccu2:0000D569A49B6E:1#STATE"}
String XX_Fenster_StateStr "Fenster [MAP(window.map):%s]" <contact> (gWindow) {channel="homematic:HMIP-SWDO:ccu2:0000D569A49B6E:1#STATE"}
Number XX_Fenster_StateNum "Fenster [MAP(window.map):%s]" <contact> (gWindow) {channel="homematic:HMIP-SWDO:ccu2:0000D569A49B6E:1#STATE"}
Switch XX_Fenster_StateSwi "Fenster [MAP(window.map):%s]" <contact> (gWindow) {channel="homematic:HMIP-SWDO:ccu2:0000D569A49B6E:1#STATE"}
interestingly the gWindow group seems to work fine eventhough the channel uses String:
openhab> smarthome:items list *gWindow*
gWindow (Type=GroupItem, BaseType=ContactItem, Members=9, State=OPEN, Label=Offene Fenster, Category=contact, Groups=[Whg])
gWindow (Type=GroupItem, BaseType=ContactItem, Members=9, State=CLOSED, Label=Offene Fenster, Category=contact, Groups=[Whg])
