i have installed the latest versions of OH2, Homegear and culfw. I also paired to thermostat devices with home gear. No I wanted to use the automatic discovery function of the Homematic Binding but unfortunately the thing search doesn’t find anything. Is this a known bug and is there any work-around?
Could you specify what is meant by “latest version”? Is this the nightly?
With the stable version it worls like a charm. First OH discovers the gateway automatically and the all devices. So the question ist if homgear is really running and how is your setup?
OK, then we should start with homegear. Could you confirm that homergear -r shows with fs 0 and ls all your devices? And does the homegear log shows any access from openhab. And shows the openhab log anny homematic errors?
sudo homegear -r
Connected to Homegear (version 0.6.19-956).
> fs 0
Device family "HomeMatic BidCoS" selected.
For information about the family's commands type: "help"
(Family)> ls
ID │ Name │ Address │ Serial Number │ Type │ Type String │ Firmware │ Config Pending │ Unreach │ Low Bat
1 │ │ 4407B0 │ XXXXXXXXXX │ 0095 │ HM-CC-RT-DN │ 1.4 │ No │ No │ No
(Family)>
Unfortunately i cant find a log for homegear under (var/log/homegear). Is there any other location?
And no… there are no errors under openhab.
That is strange. No Errors, Thing by Hand works, no homematic errors.
at the end no idea. I have homegear and OH on two different hosts and evrything works perfect. Hm maybe it is a thing with the honegear version. I am using the homegear nightlies.
