I have the problem that Openhab recognizes the keystroke several times when I press a key.
Until recently, a restart usually solved the problem. Lately that hasn’t worked either.
This is what it looks like in the log:
2023-10-12 20:15:53.895 [INFO ] [openhab.event.ChannelTriggeredEvent ] - homematic:HmIP-KRC4:3014F711A0001F9A49941E01:0002DF29B41029:3#BUTTON triggered SHORT_PRESSED
2023-10-12 20:15:53.901 [INFO ] [openhab.event.ChannelTriggeredEvent ] - homematic:HmIP-KRC4:3014F711A0001F9A49941E01:0002DF29B41029:3#BUTTON triggered SHORT_PRESSED
2023-10-12 20:15:53.908 [INFO ] [openhab.event.ChannelTriggeredEvent ] - homematic:HmIP-KRC4:3014F711A0001F9A49941E01:0002DF29B41029:3#BUTTON triggered SHORT_PRESSED
2023-10-12 20:15:53.910 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'Shelly_02' received command OFF
2023-10-12 20:15:53.926 [INFO ] [openhab.event.ChannelTriggeredEvent ] - homematic:HmIP-KRC4:3014F711A0001F9A49941E01:0002DF29B41029:3#BUTTON triggered SHORT_PRESSED
2023-10-12 20:15:53.929 [INFO ] [openhab.event.ChannelTriggeredEvent ] - homematic:HmIP-KRC4:3014F711A0001F9A49941E01:0002DF29B41029:3#BUTTON triggered SHORT_PRESSED
2023-10-12 20:15:53.932 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'Shelly_02' received command OFF
2023-10-12 20:15:53.937 [INFO ] [openhab.event.ChannelTriggeredEvent ] - homematic:HmIP-KRC4:3014F711A0001F9A49941E01:0002DF29B41029:3#BUTTON triggered SHORT_PRESSED
2023-10-12 20:15:53.939 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'Shelly_02' predicted to become OFF
2023-10-12 20:15:53.951 [INFO ] [openhab.event.ChannelTriggeredEvent ] - homematic:HmIP-KRC4:3014F711A0001F9A49941E01:0002DF29B41029:3#BUTTON triggered SHORT_PRESSED
2023-10-12 20:15:53.954 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'Shelly_02' received command OFF
2023-10-12 20:15:53.957 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'Shelly_02' received command OFF
2023-10-12 20:15:53.959 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'Shelly_02' predicted to become OFF
2023-10-12 20:15:53.961 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'Shelly_02' received command OFF
2023-10-12 20:15:53.963 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'Shelly_02' received command OFF
2023-10-12 20:15:53.965 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Shelly_02' changed from ON to OFF
2023-10-12 20:15:53.966 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'Shelly_02' predicted to become OFF
2023-10-12 20:15:53.968 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'Shelly_02' received command ON
2023-10-12 20:15:53.970 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'Shelly_02' predicted to become OFF
2023-10-12 20:15:53.973 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'Shelly_02' predicted to become OFF
2023-10-12 20:15:53.975 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'Shelly_02' predicted to become OFF
2023-10-12 20:15:53.977 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'Shelly_02' predicted to become ON
2023-10-12 20:15:53.979 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Shelly_02' changed from OFF to ON
Hatte schon mal jemand das Problem und eine Lösung dazu?
Grüße
Nico
Has anyone ever had this problem and a solution?
Greetings
Nico
