HomematicThingHandler]- Channel not found for datapoint
Hi all,
I have an homematic wall thermostat (HM-TC-IT-WM-W-EU) connected though HMCFGUSB2 → hmland → homegear → OH2 beta 3. The OH2 log shows frequently the following warnings:
2016-06-30 22:50:25.464 [WARN ] [ematic.handler.HomematicThingHandler] - Channel not found for datapoint 'NEQ0362419:2#ACTUAL_HUMIDITY'
2016-06-30 22:50:25.477 [WARN ] [ematic.handler.HomematicThingHandler] - Channel not found for datapoint 'NEQ0362419:2#ACTUAL_TEMPERATURE'
2016-06-30 22:50:25.491 [WARN ] [ematic.handler.HomematicThingHandler] - Channel not found for datapoint 'NEQ0362419:2#SET_TEMPERATURE'
2016-06-30 22:50:35.468 [WARN ] [ematic.handler.HomematicThingHandler] - Channel not found for datapoint 'NEQ0362419:2#ACTUAL_TEMPERATURE'
2016-06-30 22:50:35.484 [WARN ] [ematic.handler.HomematicThingHandler] - Channel not found for datapoint 'NEQ0362419:2#BATTERY_STATE'
2016-06-30 22:50:35.497 [WARN ] [ematic.handler.HomematicThingHandler] - Channel not found for datapoint 'NEQ0362419:2#BOOST_STATE'
2016-06-30 22:50:35.511 [WARN ] [ematic.handler.HomematicThingHandler] - Channel not found for datapoint 'NEQ0362419:2#COMMUNICATION_REPORTING'
2016-06-30 22:50:35.546 [WARN ] [ematic.handler.HomematicThingHandler] - Channel not found for datapoint 'NEQ0362419:2#CONTROL_MODE'
2016-06-30 22:50:35.562 [WARN ] [ematic.handler.HomematicThingHandler] - Channel not found for datapoint 'NEQ0362419:2#LOWBAT_REPORTING'
2016-06-30 22:50:35.575 [WARN ] [ematic.handler.HomematicThingHandler] - Channel not found for datapoint 'NEQ0362419:2#PARTY_START_TIME'
2016-06-30 22:50:35.589 [WARN ] [ematic.handler.HomematicThingHandler] - Channel not found for datapoint 'NEQ0362419:2#SET_TEMPERATURE'
2016-06-30 22:50:35.624 [WARN ] [ematic.handler.HomematicThingHandler] - Channel not found for datapoint 'NEQ0362419:2#WINDOW_OPEN_REPORTING'
2016-06-30 22:50:45.443 [WARN ] [ematic.handler.HomematicThingHandler] - Channel not found for datapoint 'NEQ0362419:0#RSSI_DEVICE'
2016-06-30 22:50:45.461 [WARN ] [ematic.handler.HomematicThingHandler] - Channel not found for datapoint 'NEQ0362419:1#HUMIDITY'
2016-06-30 22:50:45.474 [WARN ] [ematic.handler.HomematicThingHandler] - Channel not found for datapoint 'NEQ0362419:1#TEMPERATURE'
The wall thernostat is also not shown in the basic UI although Paper UI shows it at configuration > things.
How can I get OH2 to know these channels, especially actual humidity and actual temperature are of interested. And how do I get the thermostat into basic UI?
Regards,
René
