I have some Home Seer Leak Sensor HS-LS100+
I have it added and rules and items created. I can get the flood detection to work with out issue, I see
NODE 21: Updating channel state zwave:device:9d6ae427:node21:alarm_flood to ON [OnOffType]
NODE 21: Updating channel state zwave:device:9d6ae427:node21:alarm_flood to OFF [OnOffType]
But i am not seeing the node21:alarm_burglar trigger when the sensor is moved.
I am running 2.4.0-SNAPSHOT Build #1405
Any thoughts?
ITEMS
Number leak_21_temp "L21 Temperature" (Motion,persist) {channel="zwave:device:9d6ae427:node21:sensor_temperature"}
Switch leak_21_alarm_flood "L21 Alarm Flood [%s]" (Motion,persist) {channel="zwave:device:9d6ae427:node21:alarm_flood"}
Switch leak_21_alarm_heat "L21 Alarm Heat [%s]" (Motion,persist) {channel="zwave:device:9d6ae427:node21:alarm_heat"}
Switch leak_21_alarm_motion "L21 Alarm Motion [%s]" (Motion,persist) {channel="zwave:device:9d6ae427:node21:alarm_burglar"}
Number leak_21_battery "L21 Battery" (Motion,persist) {channel="zwave:device:9d6ae427:node21:battery-level"}
Rules
rule "Leak21Water"
Item leak_21_leak changed to ON
logInfo("TEST","Leak 21 water detected")
rule "Leak21Flood"
Item leak_21_alarm_flood changed to ON
logInfo("TEST","Leak 21 alarm flood")
rule "Leak21Heat"
Item leak_21_alarm_heat changed to ON
logInfo("TEST","Leak 21 alarm heat")
rule "Leak21Motion"
Item leak_21_alarm_motion changed to ON
logInfo("TEST","Leak 21 alarm motion")
Log when the device is moved
2018-12-01 20:03:57.335 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 0F 00 04 00 15 09 71 05 00 00 00 FF 07 09 00 6D
2018-12-01 20:03:57.335 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=21, callback=0, payload=00 15 09 71 05 00 00 00 FF 07 09 00
2018-12-01 20:03:57.336 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=21, callback=0, payload=00 15 09 71 05 00 00 00 FF 07 09 00
2018-12-01 20:03:57.336 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
2018-12-01 20:03:57.336 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 21: Application Command Request (ALIVE:DONE)
2018-12-01 20:03:57.336 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 21: resetResendCount initComplete=true isDead=false
2018-12-01 20:03:57.336 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 21: Incoming command class COMMAND_CLASS_ALARM, endpoint 0
2018-12-01 20:03:57.336 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 21: SECURITY not supported
2018-12-01 20:03:57.336 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 21: Received COMMAND_CLASS_ALARM V5 NOTIFICATION_REPORT
2018-12-01 20:03:57.336 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 21: NOTIFICATION report - 0 = 0, event=9, status=255, plen=0
2018-12-01 20:03:57.336 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 21: Alarm Type = BURGLAR (0)
2018-12-01 20:03:57.336 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 21: Got an event from Z-Wave network: ZWaveAlarmValueEvent
2018-12-01 20:03:57.337 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 21: Got a value event from Z-Wave network, endpoint = 0, command class = COMMAND_CLASS_ALARM, value = 255
2018-12-01 20:03:57.337 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - NODE 21: Alarm converter processing NOTIFICATION
2018-12-01 20:03:57.337 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - NODE 21: Alarm converter NOTIFICATION event is 9, type OnOffType
2018-12-01 20:03:57.337 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 21: Commands processed 1.
2018-12-01 20:03:57.337 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 21: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@51b26f46.
2018-12-01 20:03:57.337 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2018-12-01 20:03:57.337 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2018-12-01 20:03:57.337 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2018-12-01 20:03:57.394 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 0A 00 04 00 15 04 30 03 FF 08 24
2018-12-01 20:03:57.395 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=21, callback=0, payload=00 15 04 30 03 FF 08
2018-12-01 20:03:57.395 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=21, callback=0, payload=00 15 04 30 03 FF 08
2018-12-01 20:03:57.395 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
2018-12-01 20:03:57.395 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 21: Application Command Request (ALIVE:DONE)
2018-12-01 20:03:57.395 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 21: resetResendCount initComplete=true isDead=false
2018-12-01 20:03:57.395 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 21: Incoming command class COMMAND_CLASS_SENSOR_BINARY, endpoint 0
2018-12-01 20:03:57.395 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 21: SECURITY not supported
2018-12-01 20:03:57.395 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 21: Received COMMAND_CLASS_SENSOR_BINARY V2 SENSOR_BINARY_REPORT
2018-12-01 20:03:57.395 [DEBUG] [dclass.ZWaveBinarySensorCommandClass] - Processing Sensor Type 8
2018-12-01 20:03:57.395 [DEBUG] [dclass.ZWaveBinarySensorCommandClass] - Sensor Type is TAMPER
2018-12-01 20:03:57.395 [DEBUG] [dclass.ZWaveBinarySensorCommandClass] - NODE 21: Sensor Binary report, type=Tamper, value=255
2018-12-01 20:03:57.396 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 21: Got an event from Z-Wave network: ZWaveBinarySensorValueEvent
2018-12-01 20:03:57.396 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 21: Got a value event from Z-Wave network, endpoint = 0, command class = COMMAND_CLASS_SENSOR_BINARY, value = 255
2018-12-01 20:03:57.396 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 21: Updating channel state zwave:device:9d6ae427:node21:sensor_binary to ON [OnOffType]
2018-12-01 20:03:57.396 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 21: Commands processed 1.
2018-12-01 20:03:57.396 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 21: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@7048641d.
2018-12-01 20:03:57.396 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2018-12-01 20:03:57.396 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2018-12-01 20:03:57.396 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2018-12-01 20:04:00.000 [INFO ] [.eclipse.smarthome.model.script.TEST] - door1Timer: 0
2018-12-01 20:04:00.001 [INFO ] [.eclipse.smarthome.model.script.TEST] - door2Timer: 0
2018-12-01 20:04:00.002 [INFO ] [.eclipse.smarthome.model.script.TEST] - timer: 14
