I have been working with obenhab2 and homie for quite a while now.
Today I tried to add a new homie device to openhab as Thing. The autodiscovery worked fine for me but after adding it as a thing some channels had the wrong datatype or the type ‘dummy’. That’s kinda wired because I used the same code for the new device as I used for my 4 other running ones that never had a problem with datatypes.
All of the devices have the same topology besides the deviceID and names.
I tried changing the datatype to the correct one, but I dont get the edit button in the paperUI on the new Thing.
I validated the Topology with the homie tool and everything was finde besides the deprecated topics for 4.0.
Here is my topology of the new Device:
homie/lamp-v2-hexagon/$state ready
homie/lamp-v2-hexagon/$stats upTime,wifiStrength,freeHeap,minBlockSize
homie/lamp-v2-hexagon/$stats/upTime 125
homie/lamp-v2-hexagon/$stats/wifiStrength -61
homie/lamp-v2-hexagon/$stats/freeHeap 165440
homie/lamp-v2-hexagon/$stats/minBlockSize 149040
homie/lamp-v2-hexagon/$stats/interval 60
homie/lamp-v2-hexagon/$homie 3.0.1
homie/lamp-v2-hexagon/$name Table_Lamp_heaxagon
homie/lamp-v2-hexagon/$mac A4:XX:XX:XX:XX:BC
homie/lamp-v2-hexagon/$localip XX.XX.XX.XX
homie/lamp-v2-hexagon/$nodes lamp,clock,audio-source
homie/lamp-v2-hexagon/lamp/$name Leuchtquelle
homie/lamp-v2-hexagon/lamp/$type ArtLamp V2
homie/lamp-v2-hexagon/lamp/$properties brightness,color-mode,delay,color,pattern,zoom,effect,color-temperature,direction,color-running,color-running-delay,color-fade-delay
homie/lamp-v2-hexagon/lamp/brightness 1.00000000
homie/lamp-v2-hexagon/lamp/brightness/$name brightness
homie/lamp-v2-hexagon/lamp/brightness/$datatype float
homie/lamp-v2-hexagon/lamp/brightness/$settable true
homie/lamp-v2-hexagon/lamp/brightness/$retained true
homie/lamp-v2-hexagon/lamp/brightness/$unit %
homie/lamp-v2-hexagon/lamp/brightness/$format 0:1
homie/lamp-v2-hexagon/lamp/brightness/set 1.00000000
homie/lamp-v2-hexagon/lamp/color-mode 1
homie/lamp-v2-hexagon/lamp/color-mode/$name color-mode
homie/lamp-v2-hexagon/lamp/color-mode/$datatype integer
homie/lamp-v2-hexagon/lamp/color-mode/$settable true
homie/lamp-v2-hexagon/lamp/color-mode/$retained true
homie/lamp-v2-hexagon/lamp/color-mode/set 1
homie/lamp-v2-hexagon/lamp/delay 39
homie/lamp-v2-hexagon/lamp/delay/$name delay
homie/lamp-v2-hexagon/lamp/delay/$datatype integer
homie/lamp-v2-hexagon/lamp/delay/$settable true
homie/lamp-v2-hexagon/lamp/delay/$retained true
homie/lamp-v2-hexagon/lamp/delay/$format 0:255
homie/lamp-v2-hexagon/lamp/delay/set 39
homie/lamp-v2-hexagon/lamp/color 58,71,100
homie/lamp-v2-hexagon/lamp/color/$name color
homie/lamp-v2-hexagon/lamp/color/$datatype color
homie/lamp-v2-hexagon/lamp/color/$settable true
homie/lamp-v2-hexagon/lamp/color/$retained true
homie/lamp-v2-hexagon/lamp/color/$format hsv
homie/lamp-v2-hexagon/lamp/color/set 58,71,100
homie/lamp-v2-hexagon/lamp/pattern 2
homie/lamp-v2-hexagon/lamp/pattern/$name pattern
homie/lamp-v2-hexagon/lamp/pattern/$datatype integer
homie/lamp-v2-hexagon/lamp/pattern/$settable true
homie/lamp-v2-hexagon/lamp/pattern/$retained true
homie/lamp-v2-hexagon/lamp/pattern/set 2
homie/lamp-v2-hexagon/lamp/zoom 2
homie/lamp-v2-hexagon/lamp/zoom/$name zoom
homie/lamp-v2-hexagon/lamp/zoom/$datatype integer
homie/lamp-v2-hexagon/lamp/zoom/$settable true
homie/lamp-v2-hexagon/lamp/zoom/$retained true
homie/lamp-v2-hexagon/lamp/zoom/$format 0:50
homie/lamp-v2-hexagon/lamp/zoom/set 2
homie/lamp-v2-hexagon/lamp/effect 0
homie/lamp-v2-hexagon/lamp/effect/$name effect
homie/lamp-v2-hexagon/lamp/effect/$datatype integer
homie/lamp-v2-hexagon/lamp/effect/$settable true
homie/lamp-v2-hexagon/lamp/effect/$retained true
homie/lamp-v2-hexagon/lamp/effect/set 0
homie/lamp-v2-hexagon/lamp/color-temperature 0
homie/lamp-v2-hexagon/lamp/color-temperature/$name color-temperature
homie/lamp-v2-hexagon/lamp/color-temperature/$datatype integer
homie/lamp-v2-hexagon/lamp/color-temperature/$settable true
homie/lamp-v2-hexagon/lamp/color-temperature/$retained true
homie/lamp-v2-hexagon/lamp/color-temperature/set 0
homie/lamp-v2-hexagon/lamp/direction false
homie/lamp-v2-hexagon/lamp/direction/$name direction
homie/lamp-v2-hexagon/lamp/direction/$datatype boolean
homie/lamp-v2-hexagon/lamp/direction/$settable true
homie/lamp-v2-hexagon/lamp/direction/$retained true
homie/lamp-v2-hexagon/lamp/direction/set false
homie/lamp-v2-hexagon/lamp/color-running false
homie/lamp-v2-hexagon/lamp/color-running/$name color-running
homie/lamp-v2-hexagon/lamp/color-running/$datatype boolean
homie/lamp-v2-hexagon/lamp/color-running/$settable true
homie/lamp-v2-hexagon/lamp/color-running/$retained true
homie/lamp-v2-hexagon/lamp/color-running/set false
homie/lamp-v2-hexagon/lamp/color-running-delay 20
homie/lamp-v2-hexagon/lamp/color-running-delay/$name color-running-delay
homie/lamp-v2-hexagon/lamp/color-running-delay/$datatype integer
homie/lamp-v2-hexagon/lamp/color-running-delay/$settable true
homie/lamp-v2-hexagon/lamp/color-running-delay/$retained true
homie/lamp-v2-hexagon/lamp/color-running-delay/set 20
homie/lamp-v2-hexagon/lamp/color-fade-delay 20
homie/lamp-v2-hexagon/lamp/color-fade-delay/$name color-fade-delay
homie/lamp-v2-hexagon/lamp/color-fade-delay/$datatype integer
homie/lamp-v2-hexagon/lamp/color-fade-delay/$settable true
homie/lamp-v2-hexagon/lamp/color-fade-delay/$retained true
homie/lamp-v2-hexagon/lamp/color-fade-delay/set 20
homie/lamp-v2-hexagon/clock/$name Web Based RTC
homie/lamp-v2-hexagon/clock/$type RTC
homie/lamp-v2-hexagon/clock/$properties on-mode,on-hr,on-min,off-mode,off-hr,off-min,crnt,sunrise,sunset
homie/lamp-v2-hexagon/clock/on-mode 2
homie/lamp-v2-hexagon/clock/on-mode/$name on-mode
homie/lamp-v2-hexagon/clock/on-mode/$datatype integer
homie/lamp-v2-hexagon/clock/on-mode/$settable true
homie/lamp-v2-hexagon/clock/on-mode/$retained true
homie/lamp-v2-hexagon/clock/on-mode/set 2
homie/lamp-v2-hexagon/clock/on-hr 0
homie/lamp-v2-hexagon/clock/on-hr/$name on-hr
homie/lamp-v2-hexagon/clock/on-hr/$datatype integer
homie/lamp-v2-hexagon/clock/on-hr/$settable true
homie/lamp-v2-hexagon/clock/on-hr/$retained true
homie/lamp-v2-hexagon/clock/on-hr/set 0
homie/lamp-v2-hexagon/clock/on-min 0
homie/lamp-v2-hexagon/clock/on-min/$name on-min
homie/lamp-v2-hexagon/clock/on-min/$datatype integer
homie/lamp-v2-hexagon/clock/on-min/$settable true
homie/lamp-v2-hexagon/clock/on-min/$retained true
homie/lamp-v2-hexagon/clock/on-min/set 0
homie/lamp-v2-hexagon/clock/off-mode 2
homie/lamp-v2-hexagon/clock/off-mode/$name off-mode
homie/lamp-v2-hexagon/clock/off-mode/$datatype integer
homie/lamp-v2-hexagon/clock/off-mode/$settable true
homie/lamp-v2-hexagon/clock/off-mode/$retained true
homie/lamp-v2-hexagon/clock/off-mode/set 2
homie/lamp-v2-hexagon/clock/off-hr 0
homie/lamp-v2-hexagon/clock/off-hr/$name off-hr
homie/lamp-v2-hexagon/clock/off-hr/$datatype integer
homie/lamp-v2-hexagon/clock/off-hr/$settable true
homie/lamp-v2-hexagon/clock/off-hr/$retained true
homie/lamp-v2-hexagon/clock/off-hr/set 0
homie/lamp-v2-hexagon/clock/off-min 0
homie/lamp-v2-hexagon/clock/off-min/$name off-min
homie/lamp-v2-hexagon/clock/off-min/$datatype integer
homie/lamp-v2-hexagon/clock/off-min/$settable true
homie/lamp-v2-hexagon/clock/off-min/$retained true
homie/lamp-v2-hexagon/clock/off-min/set 0
homie/lamp-v2-hexagon/clock/crnt 1581888570
homie/lamp-v2-hexagon/clock/crnt/$name crnt
homie/lamp-v2-hexagon/clock/crnt/$datatype integer
homie/lamp-v2-hexagon/clock/crnt/$settable true
homie/lamp-v2-hexagon/clock/crnt/$retained true
homie/lamp-v2-hexagon/clock/crnt/set 1581888570
homie/lamp-v2-hexagon/clock/sunrise 1581834960
homie/lamp-v2-hexagon/clock/sunrise/$name sunrise
homie/lamp-v2-hexagon/clock/sunrise/$datatype integer
homie/lamp-v2-hexagon/clock/sunrise/$settable true
homie/lamp-v2-hexagon/clock/sunrise/$retained true
homie/lamp-v2-hexagon/clock/sunrise/set 1581834960
homie/lamp-v2-hexagon/clock/sunset 1581871320
homie/lamp-v2-hexagon/clock/sunset/$name sunset
homie/lamp-v2-hexagon/clock/sunset/$datatype integer
homie/lamp-v2-hexagon/clock/sunset/$settable true
homie/lamp-v2-hexagon/clock/sunset/$retained true
homie/lamp-v2-hexagon/clock/sunset/set 1581871320
homie/lamp-v2-hexagon/audio-source/$name Audio Quelle
homie/lamp-v2-hexagon/audio-source/$type Microphone
homie/lamp-v2-hexagon/audio-source/$properties gain
homie/lamp-v2-hexagon/audio-source/gain 1
homie/lamp-v2-hexagon/audio-source/gain/$name gain
homie/lamp-v2-hexagon/audio-source/gain/$datatype integer
homie/lamp-v2-hexagon/audio-source/gain/$settable true
homie/lamp-v2-hexagon/audio-source/gain/$retained true
homie/lamp-v2-hexagon/audio-source/gain/set 1
