i don’t find a working example. I have flashed the ESP8266 1MB (black version) with Homie via PlatformIO.
I have this relay modul and want to trigger the relay via Openhab. But … i think i use the wrong PIN_Relay Value?! I must trigger the GPIO0 from ESP.
My Code:
#include <Homie.h>
static const uint8_t D0 = 16;
static const uint8_t D1 = 5;
static const uint8_t D2 = 4;
static const uint8_t D3 = 0;
static const uint8_t D4 = 2;
static const uint8_t D5 = 14;
static const uint8_t D6 = 12;
static const uint8_t D7 = 13;
static const uint8_t D8 = 15;
static const uint8_t RX = 3;
static const uint8_t TX = 1;
#define firmwareVersion "1.0.0"
static const uint8_t PIN_RELAY = D0;
HomieNode lightNode("light", "Light", "switch");
bool lightOnHandler(const HomieRange& range, const String& value) {
if (value != "true" && value != "false") return false;
bool on = (value == "true");
digitalWrite(PIN_RELAY, on ? HIGH : LOW);
lightNode.setProperty("on").send(value);
Homie.getLogger() << "Light is " << (on ? "on" : "off") << endl;
return true;
void setup() {
Serial.begin(115200);
Serial << endl << endl;
pinMode(PIN_RELAY, OUTPUT);
digitalWrite(PIN_RELAY, LOW);
Homie_setFirmware("awesome-relay", firmwareVersion);
lightNode.advertise("on").setName("On").setDatatype("boolean").settable(lightOnHandler);
Homie.setup();
void loop() {
Homie.loop();
Can anyone help me?
