Hey, I created a very basic Honeywell binding using Honeywell public API.
You can find the JAR and more info in my openhab-honeywellhome repo
read the readme.md file for more info and how to integrate.
This is beta beta beta version (working on my Openhab for one week without any problem) and very basic for now. I will keep working to improve it and add more support
Good point..
I will post it once I will add some more channels and improve it a little bit more.
(or do you think it’s ok to put it there at this point?)
I think it’s OK to post something now. Just make it clear in the description that it’s a work in progress. If you keep up with the change log in the post it also makes it easier for testers to see when it’s been updated and what changed.
Way back when I messed with the API there was the ability to independently control the fan. Is that still the case? It’s my primary use case really.
Can’t wait to test it out. I have been using the Somecomfort_homie python approach. It works well for one device, but my home is zoned and I have 4 devices. I could send commands to any device just fine but only the first device would update the values in openHAB. I also used the Alexa skill, but it has limited functionality and at times (not now) , the AmazonEchoControl binding has been lees than fully reliable. I will report back once I test it.
I agree that using the Marketplace makes it easier for people to help you test it.
Thanks. I saw that I would need to adjust the refresh interval.
I appreciate the detailed authentication instructions. It was clear to me what I would need to do until I got to the 2nd paragraph of Step 4. I’m sure the problem is my lack of expertise, but would appreciate any additional hints you may have.
you will need to create a basic auth token with your Consumer Key and Consumer Secret, you can use [this]([https://developer.honeywellhome.com/api-methods](https://mixedanalytics.com/tools/basic-authentication-generator/)) for that (Consumer Key:Consumer Secret), and add to the following parameters as application/x-www-form-urlencoded` grant_type = authorization_code code = {the code you got from step number 3} redirect_uri = {your app redirect_uri} (don’t know y they need it)
If so, you need to take your Consumer Key and Consumer Secret which you should have seen in step 4. These are kind of like a username and password to authenticate that very first request for the auth token. It needs to be base64 encoded so go to https://mixedanalytics.com/tools/basic-authentication-generator/, paste in <Consumer Key>:<Consumer Secret> into the form and copy the text generated after click the “Base64” button.
Use that Base64 string in place of {YOUR_BASIC_AUTH TOKEN} in the curl request.
I made it through the authentication but ran into trouble logging in with my Honeywell credentials. It is then that I realized that my older thermostat (RTH 9250) uses the Honeywell Total Connect Comfort app and not the newer Honeywell Home app. Hopefully at some point Honeywell will merge them.
