Hi, I am adding some Honeywell Z-Wave Plug-In Smart Dimmers to my OpenHab installation. However, they are showing up as “Unknown Device” (in the Paper UI). I have updated 2.5.3 today but no luck. The device is described as follows:
Honeywell UPC: 0 30878 39336 2
Also labelled: ZW3104 (and the package says “By Jasco”)
Oddly, the manufacturer (57) seems to map to Whirlpool? I’ve got a few of these and they show the same properties. Please let me know if any additional information would be helpful. Any help or advice getting this device added to the database would be greatly appreciated!
57 decimal is 37 in hexadecimal which maps to Honeywell The identification numbers used for Z-Wave are usually expressed in hexadecimal but the Paper UI displays them in decimal.
I found the userdata/zwave/network_eb1a48d2__node_15.xml file and it resolves part of my confusion. The manufacturer id shown in the paper ui is in decimal, while the manufacturer ids in the database are in hex! (Would love to see standard prefixes used to indicate this!)
So the manufacturer is 0x39 which is Honeywell (assuming the 39 in the database is hex too!).
The same goes for the devicetype in paper, listed as 20548, but nothing comes up anywhere. Now converting to this to hex (confirmed from the xml file), the device type is 0x5044 and the id is 0x3088 which appears to be this:
Thanks Bruce! Came to the same conclusion after some head scratching.
I would attach the XML file, but it looks like new users cannot upload, so I uploaded it to Paste Bin:
The device in question is sold by Honeywell, but labelled as “by Jasco” on the box. Not sure if it should somehow be cross-listed given it has the same type and id as an existing Jasco device.
NOTE : If you find that there is already a device in the database with the same Type and ID as the one you want to add, don’t just change them or add duplicates. Please flag this to me on the openHAB forum and we’ll try and work out how best to handle it - for example, the device might be a newer (or older!) version of a similar device with different firmware.
I assume that’s what you were discussing, so I went ahead and tried to upload the XML as per the Database Guide. I registered for an account on cd-jackson.com, verified my email, but the green “Tools” button does not appear on the Device List page. I don’t see any other way to create a new item. Should I file a ticket instead?
