Hourly Tibber rates on matrix displays (e.g. Ulanzi TC001)
User story:
I would like to see a graphical representation of the hourly Tibber rates for today and tomorrow on a matrix display.
BOM:
Setup:
  1. Get your TC001 up and running (just follow the installation instructions).
  2. If you can’t read Chinese, I strongly recommend to switch the UI to English, see Ulanzi Desktop Pixel Clock TC001 Review | Blakadder's Smarthome Shenanigans.
  3. Install AWTRIX.
  4. Configure your TC001 as an AWTRIX controller (‘Atrix Simulator’, port 7001), see Ulanzi Desktop Pixel Clock TC001 Review | Blakadder's Smarthome Shenanigans.
  5. Use the AWTRIX UI to enable MQTT.
  6. Install lua and json-lua (sudo luarocks install json-lua).
  7. Copy the following script to your filesystem:
#!/bin/bash
mosquitto_pub -m "{\"remove\":\"TibberApp\"}" -h <MQTT broker IP address> -u <MQTT user> -P <MQTT password>  -t awtrix/temporaryapp
curl 2>/dev/null \
-H "Authorization: Bearer <your personal Tibber API token>" \
-H "Content-Type: application/json" \
-X POST \
-d '{ "query": "{ viewer { homes { currentSubscription{ priceInfo{ today { total } tomorrow { total } } } } } }" }' https://api.tibber.com/v1-beta/gql \
| lua create_awtrix_tibber_app.lua | tr -d '\n' | mosquitto_pub -l -h <MQTT broker IP address> -u <MQTT user> -P <MQTT password> -t awtrix/temporaryapp
  1. Adjust <your personal Tibber API token> and the MQTT parameters.
  2. Copy the following Lua script into create_awtrix_tibber_app.lua and place it in the same directory as the shell script:
json = require "JSON"
function print_color( p )
if p <= red
  print( '  "color":[255,0,0]' )
 else
  if p <= orange
    print( '  "color":[255,165,0]' )
   else
    print( '  "color":[0,255,0]' )
function analyse_day( res, today )
 red    = 0.35
 orange = 0.30
 prices = {}
 min = math.huge
 max = -math.huge
 if today
   dataset = "today"
  else
   dataset = "tomorrow"
 if #res["data"]["viewer"]["homes"][1]["currentSubscription"]["priceInfo"][ dataset ] == 24
   for x,y in pairs( res["data"]["viewer"]["homes"][1]["currentSubscription"]["priceInfo"][ dataset ])
    do
     prices[x-1] = ( y["total"] ) * 1.0
        if prices[x-1] > max
          max = prices[x-1]
      max_pos = x-1
        if prices[x-1] < min
          min = prices[x-1]
          min_pos = x-1
  diff = max - min
  red    = 7 - math.floor( ( red - min )    * 7 / diff + 0.5 )
  orange = 7 - math.floor( ( orange - min ) * 7 / diff + 0.5 )
  min_pixel = 7 - math.floor( ( min - min ) * 7 / diff + 0.5 )
  max_pixel = 7 - math.floor( ( max - min ) * 7 / diff + 0.5 )
  current_hour = os.date("*t").hour
  price_current = prices[ current_hour ]
  if not today
    print(' {')
    print( '    "type": "fill",')
    print( '     "color": [50,50,50]')
    print( '   },')
  if today
    print( '{ "type":"pixel",' )
    print( '  "position":['..current_hour..",0]," )
    print( '  "color":[255,255,255]' )
    print( '},')
    print( '  "position":['..current_hour..",7]," )
    print( '},')
  for i = 0,23 do prices[i] = 7 - math.floor( ( prices[i]-min ) * 7 / diff + 0.5 ) end
  for i = 0,23
   do
    print( '  "position":['..i..","..prices[i].."]," )
    print_color( prices[i] )
    print( '},')
  if today
    print( '{ "type":"text",' )
    print( '  "string":"' ..  math.floor( price_current * 100 + 0.5 )..'",')
    print( '  "position":[24,0],' )
    print_color( prices[ current_hour ] )
    print( '},')
    print( '{')
    print( '      "type": "show"')
        print( '    },')
    print( '    {')
    print( '      "type": "wait",')
    print( '      "ms": 10000')
    print( '    },')
   else
    print( '  "string":"' ..  math.floor( min * 100 + 0.5 )..'",')
    print_color( min_pixel )
    print( '},')
    print( '  "position":['..min_pos..",0]," )
    print( '},')
        print(' {')
    print( '    "type": "line",')
    print( '     "start": [27,7],')
    print( '     "end": [29,7],')
    print( '     "color": [255,255,255]')
    print( '   },')
    print(' {')
    print( '    "type": "pixel",')
    print( '     "position": [28,6],')
    print( '   },')
    print( '   {')
    print( '   },')
    print( '   {')
    print( '     "ms": 3000')
    print( '   },')
  if not today
    print(' {')
    print( '   },')
        print(' {')
    print( '     "start": [27,6],')
    print( '     "end": [29,6],')
    print( '   },')
    print(' {')
    print( '     "position": [28,7],')
    print( '   },')
    for i = 0,23
     do
          print( '},')
    for i = 0, 7
     do
      print(' {')
      print( '     "start": [24,'..i..'],')
      print( '     "end": [31,'..i..'],')
      print( '   },')
    print( '  "string":"' ..  math.floor( max * 100 + 0.5 )..'",')
    print_color( max_pixel )
    print( '},')
    print( '  "position":['..max_pos..",7]," )
    print( '},')
    print( '{')
    print( '    },')
    print( '    {')
    print( '    },')
  end -- data available
end -- function analyse_day
txt = io.read( '*a' )
res = json:decode( txt )
print( '{')
print( '   "name":"TibberApp",')
print( '   "lifetime":9999,')
print( '   "drawing":true,')
print( '   "data":[')
analyse_day( res, true )
analyse_day( res, false )
print( '    {')
print( '      "type": "exit"')
print( '    }')
print( '  ]')
print( '}')
  1. Execute the shell script to test your installation. I strongly recommend to use MQTT Explorer to check the installation (topic awtrix/temporaryapp):
    grafik
    The result should look like:
    Today from 7 pm to 8 pm (current hour): 30 ct/kWh
    Tomorrow from 12 noon to 1 pm lowest rate: 23 ct/kWh:
    Tomorrow from 7 pm to 8 pm highest rate: 36 ct/kWh:
Screen #1 and screen #2 are from the AWTRIX Time App and screens #3 - #5 were created by the new temporary Tibber App for AWTRIX. The white cursor marks the current hour (screen #3) and the hour with the lowest rate (screen #4) and the hour with the highest rate (screen #5), the number in the upper right corner is the current rate (screen #3), lowest (screen #4) and highest rate (screen #5) for tomorrow (unit: ct/kWh). The thresholds for the color of the graphs and the rates can be configured in the Lua script.
11. Setup a rule or use the Exec Binding to run the shell script every hour on the hour.
I am open to suggestions on how to integrate this framework into openHAB.
Edit #1:
If you are going to use the shell script via executeCommandLine: Make sure you prepend the correct path to create_awtrix_tibber_app.lua in the shell script - it took me some time to debug my openHAB rule.
Edit #2:
Min/max rates for tomorrow added, shell script and Lua script updated.
hi, i tried your script, but i get this error while running it within the command line
lua: create_awtrix_tibber_app.lua:37: attempt to get length of field '?' (a nil value)
stack traceback:
	create_awtrix_tibber_app.lua:37: in function 'analyse_day'
	create_awtrix_tibber_app.lua:249: in main chunk
	[C]: ?
Most probably your Tibber API call is wrong/incomplete. Test it:
curl 2>/dev/null \
-X POST \
-d  '{ "query": "{ viewer { homes { currentSubscription{ priceInfo{ today { total } } } } }}" }' https://api.tibber.com/v1-beta/gql
just testet it, just works fine
{"data":{"viewer":{"homes":[{"currentSubscription":{"priceInfo":{"today":[{"total":0.3164},{"total":0.2969},{"total":0.2925},{"total":0.2851},{"total":0.2828},{"total":0.2863},{"total":0.2947},{"total":0.2919},{"total":0.2821},{"total":0.2648},{"total":0.2258},{"total":0.1997},{"total":0.1983},{"total":0.189},{"total":0.1903},{"total":0.1947},{"total":0.1994},{"total":0.2227},{"total":0.2526},{"total":0.2775},{"total":0.2481},{"total":0.2255},{"total":0.2132},{"total":0.1996}]}}}]}}}
OK, shell script and Lua script in my OP didn’t match - sorry.
Replace
-d '{ "query": "{ viewer { homes { currentSubscription{ priceInfo{ today { total } } } } }}" }' https://api.tibber.com/v1-beta/gql \
with
I have updated the shell script in my OP - thanks for finding the mismatch.
I just did this but if I now execute the script within my terminal the script never finishes. I do not get any text while executing. What can I do to debug this?
Remove
from the shell script for testing purposes. Output should look like:
   "name":"TibberApp",
   "lifetime":9999,
   "drawing":true,
   "data":[
{ "type":"pixel",
  "position":[10,0],
{ "type":"pixel",
  "position":[10,7],
{ "type":"pixel",
  "position":[0,7],
  "color":[0,255,0]
{ "type":"pixel",
  "position":[1,7],
  "color":[0,255,0]
{ "type":"pixel",
  "position":[2,7],
  "color":[0,255,0]
{ "type":"pixel",
  "position":[3,7],
  "color":[0,255,0]
{ "type":"pixel",
  "position":[4,7],
  "color":[0,255,0]
{ "type":"pixel",
  "position":[5,6],
  "color":[0,255,0]
{ "type":"pixel",
  "position":[6,3],
  "color":[0,255,0]
{ "type":"pixel",
  "position":[7,3],
  "color":[0,255,0]
{ "type":"pixel",
  "position":[8,2],
  "color":[0,255,0]
{ "type":"pixel",
  "position":[9,3],
  "color":[0,255,0]
{ "type":"pixel",
  "position":[10,5],
  "color":[0,255,0]
{ "type":"pixel",
  "position":[11,7],
  "color":[0,255,0]
{ "type":"pixel",
  "position":[12,7],
  "color":[0,255,0]
{ "type":"pixel",
  "position":[13,7],
  "color":[0,255,0]
{ "type":"pixel",
  "position":[14,7],
  "color":[0,255,0]
{ "type":"pixel",
  "position":[15,7],
  "color":[0,255,0]
{ "type":"pixel",
  "position":[16,7],
  "color":[0,255,0]
{ "type":"pixel",
  "position":[17,4],
  "color":[0,255,0]
{ "type":"pixel",
  "position":[18,1],
  "color":[255,165,0]
{ "type":"pixel",
  "position":[19,0],
  "color":[255,165,0]
{ "type":"pixel",
  "position":[20,0],
  "color":[255,165,0]
{ "type":"pixel",
  "position":[21,1],
  "color":[255,165,0]
{ "type":"pixel",
  "position":[22,1],
  "color":[255,165,0]
{ "type":"pixel",
  "position":[23,2],
  "color":[0,255,0]
{ "type":"text",
  "string":"19",
  "position":[24,0],
  "color":[0,255,0]
      "type": "show"
      "type": "wait",
      "ms": 10000
      "type": "exit"
If this succeeds, check your MQTT and AWTRIX installation (cf. step 10 in my OP).
This is the output.
   "name":"TibberApp",
   "lifetime":9999,
   "drawing":true,
   "data":[
table: 0x742450
{ "type":"pixel",
  "position":[11,0],
{ "type":"pixel",
  "position":[11,7],
{ "type":"pixel",
  "position":[0,7],
  "color":[0,255,0]
{ "type":"pixel",
  "position":[1,7],
  "color":[0,255,0]
{ "type":"pixel",
  "position":[2,7],
  "color":[0,255,0]
{ "type":"pixel",
  "position":[3,7],
  "color":[0,255,0]
{ "type":"pixel",
  "position":[4,7],
  "color":[0,255,0]
{ "type":"pixel",
  "position":[5,6],
  "color":[0,255,0]
{ "type":"pixel",
  "position":[6,3],
  "color":[255,165,0]
{ "type":"pixel",
  "position":[7,3],
  "color":[255,165,0]
{ "type":"pixel",
  "position":[8,2],
  "color":[255,0,0]
{ "type":"pixel",
  "position":[9,3],
  "color":[255,165,0]
{ "type":"pixel",
  "position":[10,5],
  "color":[0,255,0]
{ "type":"pixel",
  "position":[11,7],
  "color":[0,255,0]
{ "type":"pixel",
  "position":[12,7],
  "color":[0,255,0]
{ "type":"pixel",
  "position":[13,7],
  "color":[0,255,0]
{ "type":"pixel",
  "position":[14,7],
  "color":[0,255,0]
{ "type":"pixel",
  "position":[15,7],
  "color":[0,255,0]
{ "type":"pixel",
  "position":[16,7],
  "color":[0,255,0]
{ "type":"pixel",
  "position":[17,4],
  "color":[0,255,0]
{ "type":"pixel",
  "position":[18,1],
  "color":[255,0,0]
{ "type":"pixel",
  "position":[19,0],
  "color":[255,0,0]
{ "type":"pixel",
  "position":[20,0],
  "color":[255,0,0]
{ "type":"pixel",
  "position":[21,1],
  "color":[255,0,0]
{ "type":"pixel",
  "position":[22,1],
  "color":[255,0,0]
{ "type":"pixel",
  "position":[23,2],
  "color":[255,0,0]
{ "type":"text",
  "string":"21",
  "position":[24,0],
  "color":[0,255,0]
      "type": "show"
      "type": "wait",
      "ms": 10000
      "type": "exit"
It looks nearly identical but why is there a
table …
in line 6?
Shouldn’t be there and I cannot reproduce it with the Lua script in my OP. Might be a debug output from a previous version of the Lua script. Just replace your Lua script with the current one from my OP.
now the output looks fine
   "name":"TibberApp",
   "lifetime":9999,
   "drawing":true,
   "data":[
{ "type":"pixel",
  "position":[20,0],
{ "type":"pixel",
  "position":[20,7],
{ "type":"pixel",
  "position":[0,7],
  "color":[0,255,0]
{ "type":"pixel",
  "position":[1,7],
  "color":[0,255,0]
{ "type":"pixel",
  "position":[2,7],
  "color":[0,255,0]
{ "type":"pixel",
  "position":[3,7],
  "color":[0,255,0]
{ "type":"pixel",
  "position":[4,7],
  "color":[0,255,0]
{ "type":"pixel",
  "position":[5,6],
  "color":[0,255,0]
{ "type":"pixel",
  "position":[6,3],
  "color":[255,165,0]
{ "type":"pixel",
  "position":[7,3],
  "color":[255,165,0]
{ "type":"pixel",
  "position":[8,2],
  "color":[255,0,0]
{ "type":"pixel",
  "position":[9,3],
  "color":[255,165,0]
{ "type":"pixel",
  "position":[10,5],
  "color":[0,255,0]
{ "type":"pixel",
  "position":[11,7],
  "color":[0,255,0]
{ "type":"pixel",
  "position":[12,7],
  "color":[0,255,0]
{ "type":"pixel",
  "position":[13,7],
  "color":[0,255,0]
{ "type":"pixel",
  "position":[14,7],
  "color":[0,255,0]
{ "type":"pixel",
  "position":[15,7],
  "color":[0,255,0]
{ "type":"pixel",
  "position":[16,7],
  "color":[0,255,0]
{ "type":"pixel",
  "position":[17,4],
  "color":[0,255,0]
{ "type":"pixel",
  "position":[18,1],
  "color":[255,0,0]
{ "type":"pixel",
  "position":[19,0],
  "color":[255,0,0]
{ "type":"pixel",
  "position":[20,0],
  "color":[255,0,0]
{ "type":"pixel",
  "position":[21,1],
  "color":[255,0,0]
{ "type":"pixel",
  "position":[22,1],
  "color":[255,0,0]
{ "type":"pixel",
  "position":[23,2],
  "color":[255,0,0]
{ "type":"text",
  "string":"40",
  "position":[24,0],
  "color":[255,0,0]
      "type": "show"
      "type": "wait",
      "ms": 10000
    "type": "fill",
     "color": [50,50,50]
{ "type":"pixel",
  "position":[0,5],
  "color":[255,165,0]
{ "type":"pixel",
  "position":[1,6],
  "color":[255,165,0]
{ "type":"pixel",
  "position":[2,7],
  "color":[0,255,0]
{ "type":"pixel",
  "position":[3,7],
  "color":[0,255,0]
{ "type":"pixel",
  "position":[4,7],
  "color":[0,255,0]
{ "type":"pixel",
  "position":[5,6],
  "color":[255,165,0]
{ "type":"pixel",
  "position":[6,4],
  "color":[255,165,0]
{ "type":"pixel",
  "position":[7,2],
  "color":[255,0,0]
{ "type":"pixel",
  "position":[8,1],
  "color":[255,0,0]
{ "type":"pixel",
  "position":[9,1],
  "color":[255,0,0]
{ "type":"pixel",
  "position":[10,3],
  "color":[255,165,0]
{ "type":"pixel",
  "position":[11,4],
  "color":[255,165,0]
{ "type":"pixel",
  "position":[12,5],
  "color":[255,165,0]
{ "type":"pixel",
  "position":[13,5],
  "color":[255,165,0]
{ "type":"pixel",
  "position":[14,5],
  "color":[255,165,0]
{ "type":"pixel",
  "position":[15,5],
  "color":[255,165,0]
{ "type":"pixel",
  "position":[16,5],
  "color":[255,165,0]
{ "type":"pixel",
  "position":[17,4],
  "color":[255,165,0]
{ "type":"pixel",
  "position":[18,1],
  "color":[255,0,0]
{ "type":"pixel",
  "position":[19,0],
  "color":[255,0,0]
{ "type":"pixel",
  "position":[20,2],
  "color":[255,0,0]
{ "type":"pixel",
  "position":[21,2],
  "color":[255,0,0]
{ "type":"pixel",
  "position":[22,4],
  "color":[255,165,0]
{ "type":"pixel",
  "position":[23,5],
  "color":[255,165,0]
{ "type":"text",
  "string":"29",
  "position":[24,0],
  "color":[0,255,0]
{ "type":"pixel",
  "position":[3,0],
    "type": "line",
     "start": [27,7],
     "end": [29,7],
    "type": "pixel",
     "position": [28,6],
     "type": "show"
     "type": "wait",
     "ms": 3000
    "type": "fill",
     "color": [50,50,50]
    "type": "line",
     "start": [27,6],
     "end": [29,6],
    "type": "pixel",
     "position": [28,7],
{ "type":"pixel",
  "position":[0,5],
  "color":[255,165,0]
{ "type":"pixel",
  "position":[1,6],
  "color":[255,165,0]
{ "type":"pixel",
  "position":[2,7],
  "color":[0,255,0]
{ "type":"pixel",
  "position":[3,7],
  "color":[0,255,0]
{ "type":"pixel",
  "position":[4,7],
  "color":[0,255,0]
{ "type":"pixel",
  "position":[5,6],
  "color":[255,165,0]
{ "type":"pixel",
  "position":[6,4],
  "color":[255,165,0]
{ "type":"pixel",
  "position":[7,2],
  "color":[255,0,0]
{ "type":"pixel",
  "position":[8,1],
  "color":[255,0,0]
{ "type":"pixel",
  "position":[9,1],
  "color":[255,0,0]
{ "type":"pixel",
  "position":[10,3],
  "color":[255,165,0]
{ "type":"pixel",
  "position":[11,4],
  "color":[255,165,0]
{ "type":"pixel",
  "position":[12,5],
  "color":[255,165,0]
{ "type":"pixel",
  "position":[13,5],
  "color":[255,165,0]
{ "type":"pixel",
  "position":[14,5],
  "color":[255,165,0]
{ "type":"pixel",
  "position":[15,5],
  "color":[255,165,0]
{ "type":"pixel",
  "position":[16,5],
  "color":[255,165,0]
{ "type":"pixel",
  "position":[17,4],
  "color":[255,165,0]
{ "type":"pixel",
  "position":[18,1],
  "color":[255,0,0]
{ "type":"pixel",
  "position":[19,0],
  "color":[255,0,0]
{ "type":"pixel",
  "position":[20,2],
  "color":[255,0,0]
{ "type":"pixel",
  "position":[21,2],
  "color":[255,0,0]
{ "type":"pixel",
  "position":[22,4],
  "color":[255,165,0]
{ "type":"pixel",
  "position":[23,5],
  "color":[255,165,0]
{ "type":"text",
  "string":"37",
  "position":[24,0],
  "color":[255,0,0]
{ "type":"pixel",
  "position":[19,7],
      "type": "show"
      "type": "wait",
      "ms": 3000
      "type": "exit"
but within mqtt explorer i see the following only:
Bildschirmfoto 2023-04-11 um 20.54.30
and
Bildschirmfoto 2023-04-11 um 20.54.53
The script itself never finishes. I have to press ctrl+c to kill the script.
Any idea what is still going wrong.
Thank you very much for your great help.
edit:
do i have to put the custom app into the AppLoop within AWTRIX? or should it be displayed right away?
If
#!/bin/bash
curl 2>/dev/null \
-X POST \
outputs the JSON for the temporary Tibber app (and does publish to awtrix/temporaryapp as your result from MQTT Explorer proves), piping the result to tr and then to mosquitto_pub should work and shouldn’t be blocking. Check your second mosquitto_pub command in the shell script for errors (correct broker IP, user, password?). No need to put the temporary app created by the Lua script into the app loop - that’s what the second call to mosquitto_pub in the shell script is for.
BTW, activeApp = Notification/CustomApp looks strange as it isn’t valid JSON.
HI,
i just found my problem.
The problem was the last mqtt publish.
Instead of
for me the following is working
mosquitto_pub -s -h <MQTT broker IP address> -u <MQTT user> -P <MQTT password> -t awtrix/temporaryapp
Thanks a lot for your support
HI,
one last question.
I would like to ad a fourth color.
Would this be correct?
if p <= red
 else
  if p <= orange
   else
    if p <= yellow
      print( '  "color":[255,255,0]' )
     else
 red    = 0.35
 orange = 0.30
 yellow = 0.25
So i would like to have:
pricer higher than 0.35 → red
price between 0.3 and 0.35 → orange
price between 0.25 and 0.3 → yellow
price below 0.25 → green
Thanks a lot.
You would have to add at least one additional line (search for orange to find all places in the Lua script):
yellow = 7 - math.floor( ( yellow - min ) * 7 / diff + 0.5 )
One additional remark:
The Lua script doesn’t handle switching from/to DST. It should be easy to add it to the Lua script (just check for 23 or 25 price values and …).
What do you mean with switching from/to DST?
In some regions, clocks are set forward/back once a year. This results in 23 or 25 price values. The Lua script will not work on these days.
I would like to repeat the three „images“ two times.
But if I add
repeat:2
the last image is overlayed with the first one.
So I think I need to draw an empty image for 1ms after the third image.
But everything I tried did not work.
Can you help me?
For detailed explanations of writing AWTRIX applications, see https://awtrixdocs.blueforcer.de/#/en-en/api. Try the clear command. However, AWTRIX is EOL and closed source, so you are on your own with AWTRIX, e.g. I couldn’t get the MQTT topic awtrix/draw to work.
