How can I completely disable RRD4J?
I have successfully installed influxDb.
So I want to disable rrd4j completely.
I removed it from the “Add-On Store”
But there are still log messages when starting Openhab.
What is the right way to disable rrd4j completely?
Here the log messages
2024-03-24 12:08:39.584 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'influxdb.persist'
2024-03-24 12:08:40.015 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'rrd4j.persist'
Delete the file rrd4j.persist
thanks, deleting
/etc/openhab/persistence/rrd4j.persist
solved the problem
You should also uninstall the add on. You can find it under the persistence tab in the add-ons store.
He already did
