You likely need to change the regex expression in the items file. Try just reading the temperature rather than both and see if that works. If it does then that is likely your problem. If you return both as demonstrated in the code the regex for temp will need to select the first number and the regex for humidity will need to select the second number.
sry im a absolutely openhab2 newbie
all what i have done are the steps what referred from nguyen.
item
Number Temp "Temperature [%.2f C]" <temperature> {exec="<[/usr/bin/python /opt/openhab/configurations/scripts/AdafruitDHT.py:10000:REGEX((.*?))]"}
python script
import sys
import Adafruit_DHT
sensor = Adafruit_DHT.DHT11
pin = 4
humidity, temperature = Adafruit_DHT.read_retry(sensor, pin)
if humidity is not None and temperature is not None:
print('{0:0.2f}'.format(temperature))
else:
print('Failed to get reading. Try again!')
sys.exit(1)
all what i see in openhab logs is "item temp removed…"
maybe you can help me
I have a similar approach and read the sensor values via SSH in a shell script. I paired the OpenHAB Server and the Raspberry with SSH-Keys and run something like that in a rule:
val TEMP = executeCommandLine("/x/x/openhab/runtime2/conf/scripts/rasp_keller.sh@@TEMP", 5000)
if (TEMP.toString().length <= 5) tmp_keller.postUpdate(TEMP)
where the shell script is something like:
#!/bin/bash
case $1 in
TEMP) raw=$(ssh pi@192.168.x.x "sudo ./DHT22.py" | awk '{print $1}')
HUMID) raw=$(ssh pi@192.168.x.x "sudo ./DHT22.py" | awk '{print $2}')
esac
echo "$raw"
The python script on the Raspberry is the example from Adafruit. Very easy and works perfectly, maybe not the most professional way, but okay for me.
Greetings
can you read local sensors with your ssh script?
maybe you can post a tutorial from your ssh setup
no, local on the raspberry, which has the DHTxx to his GPIO connected, i read the data with this example from adafruit: https://learn.adafruit.com/dht-humidity-sensing-on-raspberry-pi-with-gdocs-logging/software-install-updated
then i pair the OpenHAB Server with the raspberry via ssh keypairs (German: https://wiki.ubuntuusers.de/SSH/)
then i can execute that adafruit example remotely with my shell script from the OpenHAB Server and work with the answer and put them into my items via rules…
EDIT:
sorry, i didn’t see that you have the DHT connected on your openhab server…
Then you only need to take the adafruit example, put your sensor and sensorpin in there and execute it from within a rule!
you can build for example 2 *.py files, one for the temperature and one for the humidity and then get your values like i do within a rule
thats what i trying…but it doesnt works.
can you give me a rule and item example?
i can read all data via ssh and the example adafruit script, no problem.
but there are no data in oh2.
Try this:
Items:
Number tmp_keller "Keller [%.1f °C]"
Number humidity_keller "Keller [%.1f %%]"
Rule:
rule "Keller"
Time cron "0 */5 * * * ?"
val TEMP = executeCommandLine("/pathToPythonScriptWithOnlyTemperature.py", 5000)
Thread::sleep(5000)
val HUMID = executeCommandLine("/pathToPythonScriptWithOnlyHumidity.py", 5000)
if (HUMID.toString().length <= 5) humidity_keller.postUpdate(HUMID)
logInfo("Keller", "Temperatur: " + TEMP.toString() + "°C, Feuchte: " + HUMID.toString() + "%")
wtf…it works now
1000 x thx fo your help.
next step: some graphs, but not today anymore
sry but these are my first steps with openhab.
i understand the item, sitemap things but i should work with rules-wiki.
also dann danke nochmals stefan!!!
Cool! Glad i could help! Feel free to ask if there are questions within that small code!
Gerne, dafür ist das Ganze hier
Today i test the script, and i have strange reading from DHT11 sensor, the value of temperature and humidity from the sensors are floating. If temperature is 9 degree Celsius one reading is 9 next reading is 4. and humidity is the same if humidity is 35% one reading is 35% some readings after is 140%. I use DHT11 reading every 5 seconds, power sensors with 3.3V and i have resistor 4K8 to VCC and Signal. Trying also to read sensor every 60sek… the same think, down on the link is picture of the chart. Is anybody have idea whats wrong? what have to check?
https://www.dropbox.com/s/4vucx1en23tnzwv/Screenshot%202017-02-19%2012.29.40.png
I have a DTH11, its working ok when I run it from the command line using horschte instructions, but the SItemap shows no values. The text and the icons are there but ther are no values for temp or the Humidity.
I should be missing something. There are no errors in the logs.
I also tried spy0r aproach and the same thing happens.
Any idea what I’m doing wrong ?
Thanks for the help
If you don’t provide any information that is almost impossible …
Post your items and sitemap entries and tell us on which topic you are receiving your temp and hum values.
Sorry for beeing short on the information. Here goes:
Sitemap:
sitemap default label=“Sitemap Vila Alice”{
Frame label=“Demo” {
Text item=Temp1 label="Temperatura1 [%.2f ºC]"
Switch item=Wifi_ZAP label="ZAP 192.168.1.1"
Text item=temp_k
Text item=humidity_keller
Text item=TempA
Items:
Switch Wifi_ZAP “ZAP 192.168.1.1” {channel=“network:device:192_168_1_1:online”}
Number Temp1 “Temperatura1 [%.2f C]” {exec="<[python /etc/openhab2/scripts/temperatura.py:10000:REGEX((.?))]"}
Number temp_k “Keller [%.1f °C]”
Number humidity_keller “Keller[%.1f %%]”
Number TempA “TemperaturaA [%.2f C]” {exec="<[sudo /usr/bin/python /etc/openhab2/scripts/AdafruitDHT.py:10000:REGEX((.?))]"}
Rules:
Keller.rules
rule "Keller"
val TEMP = executeCommandLine(“python /etc/openhab2/scripts/temperatura.py”, 5000)
Thread::sleep(5000)
val HUMID = executeCommandLine(“python /etc/openhab2/scripts/humidade.py”, 5000)
logInfo(“Keller”, "Temperatur: " + TEMP.toString() + "°C, Feuchte: " + HUMID.toString() + “%”)
As I mentioned before temperture.py and AdafruitDHT.py both run ok on the command line.
There’s no error on the log
The sitemap apears Ok, but no values are dispalyed.
Paulo
This is the display of the Sitemap (copy /paste):
Demo
Temperatura1
- ºC
ZAP 192.168.1.1
Keller - °C
Keller - %
TemperaturaA - C
Unfortunately I have never used any Phyton scripts with the exec binding and therefore am not able to help.
The only hint I can give you: is openHAB able to read the *.py scripts?
When you execute them from the command line you normally have a different user (or even root) as whether you want openHAB (user:group openhab:openhab) to read the file …
Thanks for your hint.
After your answer I checked the permissions in:
http://docs.openhab.org/installation/linux.html#network-sharing
and followed the info in:
http://raspberrypi.stackexchange.com/questions/40105/access-gpio-pins-without-root-no-access-to-dev-mem-try-running-as-root
In the Paper UI its already working
Hi guys
I’m new with openhab.
Can anyone do like a step by step guide how to get the DHT working?
ex: Go to items tab, do this and this then install with SSH Adafrui DHT…
Hi Friends, I’m doing the above. But I can not read the OH2 data. Please be glad if you share some more descriptive information.
Below is the code I am writing;
Number HomeTemperature “Temperature [%.1f °C]” {exec="<[/usr/bin/python /home/openhabian/AdafruitDHT.py:10000:REGEX((.*?))]"}
Have you used openhab.openhab for the group.user ?
Hi Stefan, I like your ssh approach to remote raspberrys. I am stuck at the following: As far as I see the executeCommandLine launches as user openhab? Who did you manage to generate ssh keys for this user in order to login to the remote raspberry?
Thanks.
