Cool! Glad i could help! Feel free to ask if there are questions within that small code!
Gerne, dafür ist das Ganze hier
Today i test the script, and i have strange reading from DHT11 sensor, the value of temperature and humidity from the sensors are floating. If temperature is 9 degree Celsius one reading is 9 next reading is 4. and humidity is the same if humidity is 35% one reading is 35% some readings after is 140%. I use DHT11 reading every 5 seconds, power sensors with 3.3V and i have resistor 4K8 to VCC and Signal. Trying also to read sensor every 60sek… the same think, down on the link is picture of the chart. Is anybody have idea whats wrong? what have to check?
https://www.dropbox.com/s/4vucx1en23tnzwv/Screenshot%202017-02-19%2012.29.40.png
I have a DTH11, its working ok when I run it from the command line using horschte instructions, but the SItemap shows no values. The text and the icons are there but ther are no values for temp or the Humidity.
I should be missing something. There are no errors in the logs.
I also tried spy0r aproach and the same thing happens.
Any idea what I’m doing wrong ?
Thanks for the help
If you don’t provide any information that is almost impossible …
Post your items and sitemap entries and tell us on which topic you are receiving your temp and hum values.
Sorry for beeing short on the information. Here goes:
Sitemap:
sitemap default label=“Sitemap Vila Alice”{
Frame label=“Demo” {
Text item=Temp1 label="Temperatura1 [%.2f ºC]"
Switch item=Wifi_ZAP label="ZAP 192.168.1.1"
Text item=temp_k
Text item=humidity_keller
Text item=TempA
Items:
Switch Wifi_ZAP “ZAP 192.168.1.1” {channel=“network:device:192_168_1_1:online”}
Number Temp1 “Temperatura1 [%.2f C]” {exec="<[python /etc/openhab2/scripts/temperatura.py:10000:REGEX((.?))]"}
Number temp_k “Keller [%.1f °C]”
Number humidity_keller “Keller[%.1f %%]”
Number TempA “TemperaturaA [%.2f C]” {exec="<[sudo /usr/bin/python /etc/openhab2/scripts/AdafruitDHT.py:10000:REGEX((.?))]"}
Rules:
Keller.rules
rule "Keller"
Time cron "0 */5 * * * ?"
val TEMP = executeCommandLine(“python /etc/openhab2/scripts/temperatura.py”, 5000)
if (TEMP.toString().length <= 5) tmp_keller.postUpdate(TEMP)
Thread::sleep(5000)
val HUMID = executeCommandLine(“python /etc/openhab2/scripts/humidade.py”, 5000)
if (HUMID.toString().length <= 5) humidity_keller.postUpdate(HUMID)
logInfo(“Keller”, "Temperatur: " + TEMP.toString() + "°C, Feuchte: " + HUMID.toString() + “%”)
As I mentioned before temperture.py and AdafruitDHT.py both run ok on the command line.
There’s no error on the log
The sitemap apears Ok, but no values are dispalyed.
Paulo
This is the display of the Sitemap (copy /paste):
Demo
Temperatura1
Unfortunately I have never used any Phyton scripts with the exec binding and therefore am not able to help.
The only hint I can give you: is openHAB able to read the *.py scripts?
When you execute them from the command line you normally have a different user (or even root) as whether you want openHAB (user:group openhab:openhab) to read the file …
Thanks for your hint.
After your answer I checked the permissions in:
http://docs.openhab.org/installation/linux.html#network-sharing
and followed the info in:
http://raspberrypi.stackexchange.com/questions/40105/access-gpio-pins-without-root-no-access-to-dev-mem-try-running-as-root
In the Paper UI its already working
Hi guys
I’m new with openhab.
Can anyone do like a step by step guide how to get the DHT working?
ex: Go to items tab, do this and this then install with SSH Adafrui DHT…
Hi Friends, I’m doing the above. But I can not read the OH2 data. Please be glad if you share some more descriptive information.
Below is the code I am writing;
Number HomeTemperature “Temperature [%.1f °C]” {exec="<[/usr/bin/python /home/openhabian/AdafruitDHT.py:10000:REGEX((.*?))]"}
Have you used openhab.openhab for the group.user ?
Hi Stefan, I like your ssh approach to remote raspberrys. I am stuck at the following: As far as I see the executeCommandLine launches as user openhab? Who did you manage to generate ssh keys for this user in order to login to the remote raspberry?
Thanks.
just use “sudo -u openhab” or “su openhab” before keygen/ssh-copy-id!
Just for completeness sake, may I add this link https://github.com/psyciknz/OpenHAB-Scripts/blob/master/mqtt.dhtsensor.py
That did the trick! Many thanks.
I directly read out the oneWire ds18b20 but it should be similar for the dth22.
Thanks, I think I am getting pretty close.
However in the Log-file it shows that I still have a permissions problem.
2019-01-04 12:17:00.077 [WARN ] [lipse.smarthome.io.net.exec.ExecUtil] - Execution failed (Exit value: -559038737. Caused by java.io.IOException: Cannot run program “/etc/openhab2/scripts/DHT22_temp.py” (in directory “.”): error=13, Permission denied)
I checked the permissions of the scripts folder:
[12:09:15] openhabian@openHABianPi:~$ ls -ld /etc/openhab2/scripts/
drwxrwxr-x+ 2 openhab openhabian 4096 Jan 4 11:53 /etc/openhab2/scripts/
I tried to chmod the directory to 777 with sudo chmod 777 /etc/openhab2/scripts/ via SSH, but it doesn’t work.
The python scripts themselves work. I can execute them via SSH (even without su command) and get the measurement values.
Since I don’t need the su command when I run the files I don’t get why it doesn’t work when I run the exec via the rules.
Can someone help me along?
I needed to add pyhton before the path to the script.
Thefore my code looks like this:
val TEMP = executeCommandLine(“python /etc/openhab2/scripts/DHT22_temp.py”, 5000)
This also solved my permission problem that I described lower in the thread.
