I am a openHABian beginner setting up a electricity spot market control system as the electricity prices here in Finland is sky rocketing for now. After a lot of try and error I have been able to set up openHABian 64bit and InfuxDB2 on my Raspberry Pi 4.
For almost aweek now I have tried to get my scripts running with no luck. Googling for help has not been successful either. The scripts are known to be running correctly on a other openHAB members installation.
Running any of my scripts ends with the same error: 2022-09-13 08:45:09.580 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID â5fe8f3d523â failed: org.graalvm.polyglot.PolyglotException: EvalError: /etc/openhab/automation/js/node_modules/kotikolo/fmi.js
My rule script is here,
configuration: {}
triggers:
- id: "1"
configuration:
time: 09:30
type: timer.TimeOfDayTrigger
conditions: []
actions:
- inputs: {}
configuration:
type: application/javascript;version=ECMAScript-2021
script: |
fmi = require('kotikolo/fmi.js');
influx = require('kotikolo/influx.js');
// Place recognized by Finnish Meteorology Institute's API.
place = 'numminen';
// Read weather forecast and write them to the database.
points = fmi.getForecast(place);
influx.writePoints('fmi_forecast_temperature', points);
type: script.ScriptAction
and the fmi.js script here,
* Javascript module for reading weather data from FMI API.
* Copyright (c) 2022 Markus Sipilä.
* Permission to use, copy, modify, and/or distribute this software for any
* purpose with or without fee is hereby granted, provided that the above
* copyright notice and this permission notice appear in all copies.
* THE SOFTWARE IS PROVIDED "AS IS" AND THE AUTHOR DISCLAIMS ALL WARRANTIES WITH
* REGARD TO THIS SOFTWARE INCLUDING ALL IMPLIED WARRANTIES OF MERCHANTABILITY
* AND FITNESS. IN NO EVENT SHALL THE AUTHOR BE LIABLE FOR ANY SPECIAL, DIRECT,
* INDIRECT, OR CONSEQUENTIAL DAMAGES OR ANY DAMAGES WHATSOEVER RESULTING FROM
* LOSS OF USE, DATA OR PROFITS, WHETHER IN AN ACTION OF CONTRACT, NEGLIGENCE
* OR OTHER TORTIOUS ACTION, ARISING OUT OF OR IN CONNECTION WITH THE USE OR
* PERFORMANCE OF THIS SOFTWARE.
* Exports.
module.exports = {
getForecast: getForecast,
* Reads the weather forecase from FMI API.
* @param string place
* Place recoginzed by FMI API.
* @return string
* XML response from FMI API.
function getForecast(place) {
const xml = makeApiCall(place);
const points = preparePoints(xml);
return points;
* Makes an API call to the Finnish Meteorology Institute.
* @return string
function makeApiCall(place) {
const http = Java.type("org.openhab.core.model.script.actions.HTTP");
console.log('fmi.js: Making an API call to FMI API...');
const url = 'http://opendata.fmi.fi/wfs?service=WFS&version=2.0.0&request=getFeature&storedquery_id=fmi::forecast::hirlam::surface::point::timevaluepair&place=' + place;
const xml = http.sendHttpGetRequest(url, 10000);
return xml;
* Parses the forecasted temperatures from the XML response.
* @param string xml
* FMI response in XML format.
* @return array
* Array of point objects.
function preparePoints(xml) {
console.log('fmi.js: transforming XML to JSON and parsing temperatures...');
const transformation = Java.type("org.openhab.core.transform.actions.Transformation");
let tempPoints = [];
// Early exit in case XML is null.
if (xml == null) {
console.error('fmi.js: XML empty, parsing aborted.')
return tempPoints;
try {
const jsObject = JSON.parse(transformation.transform('XSLT', 'xml2json.xsl', xml));
const members = jsObject['wfs:FeatureCollection']['wfs:member'];
for (let i = 0; i < members.length; i++) {
let feature = members[i]['omso:PointTimeSeriesObservation']['om:featureOfInterest']['sams:SF_SpatialSamplingFeature'];
if (feature['gml:id'] == 'enn-s-1-1-Temperature') {
let tsPoints = members[i]['omso:PointTimeSeriesObservation']['om:result']['wml2:MeasurementTimeseries']['wml2:point'];
for (let j = 0; j < tsPoints.length; j++) {
let point = {
datetime: tsPoints[j]['wml2:MeasurementTVP']['wml2:time'],
value: tsPoints[j]['wml2:MeasurementTVP']['wml2:value']
tempPoints.push(point);
console.log('fmi.js: Temperatures parsed!');
catch (exception) {
console.error('fmi.js: Exception parsing temperatures: ' + exception.message);
return tempPoints;
Any help is greatly appreciated - my head is starting to hurt from banging it to the wall
What version of OH is it working on and what version is it but working on?
This is a third party library you installed using NPM I assume?
Is there nothing after that error, like a stack trace or the like?
A quick hint whether or not the installed it is if you see GraalVM mentioned, theyâve installed the add-on. Right now the JS Scripting add-on is the only one that uses it.
Iâm running openHAB 3.3.0 on openHabian, also on Raspberry Pi 4 like @ruxu
I was first suspecting that the path in the require statement would be incorrect, so I modified my script action so that the path was incorrect. That results in a different error message in the logs, that would be org.graalvm.polyglot.PolyglotException: TypeError: Cannot load CommonJS module: 'invalid-path-here/fmi.js'
So that suggests (does not prove, but suggests) that @ruxuâs script action is able to read the fmi.js from /etc/openhab/automation/js/node_modules/kotikolo/fmi.js
Executing this script action should result in the following log entry that looks like this: 2022-09-13 21:15:15.258 [INFO ] [g.openhab.automation.script.ui.hello] - Hello World!
Noniin, Iâm almost sure I figured it out. This is most likely a file permission error. I was able to repro the error message by modifying the file permissions so that openhab does not have read access to the file.
openHab runs as a Linux user âopenhabâ. You canât log in to your Raspberry with this user account because the the shell login is disabled for this user. So you must have created the js file with some other user, but the file / directory permissions are so that openhab canât read the file.
You can change the file owner and group like this:
In /etc/openhab/automation/js/node_modules
chown -R your-user:openhab kotikolo
This should recursively change the file owners so that your user still owns the files but openhab is added as the group.
You can see the file owner, group and file permissions with ls -la. The correct permissions for the js files would be -rw-r--r--. For the kotikolo directory, the permissions should be drwxrwxr-x
Thank you for your quick response and suggestions on what to check out. Unfortunately though the problem was not solved. The directory and file rights are as you described after running chown.
When running your hello-world script example I now get a different error message,
2022-09-14 15:46:06.700 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID âacd9415235â failed: org.graalvm.polyglot.PolyglotException: TypeError: Cannot load CommonJS module: âkotikolo/hello-world.jsâ
Could there be a difference in our basic installations - I am running latest openHABian 64bit + InfluxDB2 and all the add-ons you have listed? Everything is at this stage on the SD card. Could there be any small detail in your installation that is not listed in your very detailed instructions?
I got to struggle on - it will be solved at some point, with some persistenceâŚ
The only difference that I can see compared to what I have on my installation is that I have also changed the file owner of the js files to be openhab, you have them owned by openhabian. That should not make any difference, because the openhab gropu has also read and write permissions.
Did you re-save your rule AFTER you modified the file permissions? Whenever the js files are modified, the rule must be re-saved. Otherwise openHab will continue to use the previously loaded version of the file.
Yes I have saved the rules everytime after any change but still no luck. Could there be something wrong in my setup so that the binding between the two script functions are unrecognized?
I made a test rule where there in the first script was only the request statement for the second script and a log message_1. In the second script I put only a log message_2 and nothing else. When the rule was run both messages where printed out to the log and no error messages shown.
So at least it seems that the file rights are correct and the second script file can be run.
But if you run the rule again only the first script message_1 one is printed out propably because the second script request is memorized?
So youâre saying that you are able to run some other js files from the same /etc/openhab/automation/js/node_modules/kotikolo directory, but the fmi.js and hello-world.js both fail?
Can you show the actual code what script and rule you managed to get working?
I donât use .js files for my rules. But isnât it the case that your .js files that need to be treated like rules need to be in the $OH_CONF/automation/js folder (or a subfolder not under node_modules)? Maybe itâs being loaded but not executed because OH thinks itâs a library.
Regarding the scripts for my application they are all running now without errors - so for the time being I am in a donât fix it, if it ainât broken situationâŚ
Better hit my next issue when running pigpio,
2022-09-16 18:14:04.241 [WARN ] [l.handler.PigpioDigitalOutputHandler] - An error occured while changing the gpio value: (-99999999)
