- Platform information: openhabian
- Hardware: pi-b2+
- openHAB version: openhab2
I’ve configured habpanel, and I’m using a touch screen, How can I start the habPanel at start up as default and full screen mode?
hello
you want to start a browser and load HabPanel in it on your openhabian machine?
as far as I know there i no X Server running on the standard openhabian image.
assuming you have a machine running with X you could use something like this:
nohup chromium-browser --app=http://<<ip_of_openhab_machine>>:8080/habpanel/#/ --start-fullscreen --hide-scrollbar &
most likely you have to export your DISPLAY variable before, like
export DISPLAY=:0.0
if you add both lines two a small bash script, make it executable and autostart it I guess you get what you want.
cheers
yes that is exactly what I want to accomplish here
cool, than above mentioned should do the trick.
you have to install an XServer on you machine and you can start a browser via autostart.
A Pi2 is already underpowered. Adding an xserver will make performance even worse.
that is of course true, that won’t be enough for any serious usage.
however for a proof of concept and/or playing around it might be ok, although it won’t make any fun to work with it
So, what do you suggest guys, I need to make this work
pi+openhab+habpanel+touch lcd
I suggest looking in a Raspberry Pi forum for their expert advice since you did not like the solution presented in post 2 here. Once you get a browser running at startup, then you can return here for openHAB specific advice.
