How can I put a popup link on top of the label from an oh-toggle-item
Hi there,
how can I have an oh-toogle-item and open an popup if I only click on the label and not on the toggle?
The idea is to have a dimmer in an popup window.
uid: widget_all_lights
tags:
  - card
  - lights
props:
  parameters: []
  parameterGroups: []
timestamp: Nov 7, 2021, 9:34:47 PM
component: f7-card
  title: Aktive Lichter
slots:
  default:
    - component: oh-list
      slots:
        default:
          - component: oh-repeater
              for: item
              sourceType: itemsWithTags
              itemTags: Switch,Light
              fragment: true
              filter: items[loop.item.name].state == "ON" || items[loop.item.name].state > 0
            slots:
              default:
                - component: oh-toggle-item
                    icon: f7:lightbulb
                    iconColor: yellow
                    color: yellow
                    title: =loop.item.label
                    item: =loop.item.name
                    #action: popup
                    #actionModal: widget:card_dimmer_popup_window
                    #actionModalConfig:
                    #  item: =loop.item.name
                    #  title: =loop.item.label
Short answer: I don’t think you can with the oh widgets, you’ll have to construct it yourself from the base f7 widgets.
Long answer: The oh actions trigger off of the entire area of the widget, so even if you add an oh-toggle item to an oh-list-item and then give the list item an action, every time you click the toggle it will also trigger the action.
An f7-list-item is the base for the oh-list-item but it doesn’t have the actions baked in. The f7 component does have all the slots that you need to simulate the oh widget. You’ll just want to put an oh-link with the label you want in the title slot. You can then give that link the actions you want. Next you can add an oh-toggle to the after slot of the f7-list-item and connect that to the item of interest.
Hi Justin,
you explaination makes absolute sence, but somehow I don’t get it sorted out.
Can you please help me out further with a code example?
Where you have an oh-toggle-item you need to replace it with an f7-list-item. The f7 version won’t have all the same properties as the oh version, but you don’t need much (and you can always use [ctrl]+[space] in the widget editor to see the list of available config options when you are in the config section of a widget). The oh options will come from adding other widgets inside the f7. It will look something like this:
- component: f7-list-item
  config: {}
  slots:
    title:
      - component: oh-link
          text: =your appropriate loop label variable here
          other action configs....
    after:
          item =your appropriate loop name variable here
          other toggle configs...
*- just typed up not tested, beware of typos
Hi Justin,
thank you again for your support. I played all evening with different solutions with now all technical work, but they don’t look nearly the same like the original oh-toggle-item.
here is my code:
                    icon: f7:lightbulb
                    iconColor: yellow
                    color: yellow
                    action: popup
                    style:
                      padding: 4px
                  slots:
                    content-start:
                      - component: f7-icon
                          f7: lightbulb
                          color: yellow
                    title:
                          text: =loop.item.label
                          color: white
                          action: popup
                          actionModalConfig:
                    after-title:
                          color: yellow
                    icon: f7:lightbulb
                    iconColor: yellow
                    color: yellow
                    action: popup
                    style:
                      padding: 4px
                  slots:
                    content-start:
                          f7: lightbulb
                          color: yellow
                    title:
                          color: white
                          action: popup
                          actionModalConfig:
                    after-title:
                          color: yellow
The result looks like:
I tried all these different slots I found here:
But no combination gives me the same result.
My example only used two child components to the custom list item. You’ve added a third. The f7-list-item, by default uses flex spacing on its children which does its best to responsively evenly distribute the children in the available space. That means as soon as you added the third component to the list item, the even spacing put one component in the middle. There are two fairly easy solutions to this:
  1. Keep your three different items but combine the first two under their own f7-row component. This will keep those two on one side and the toggle on the other as the list item will think it’s only trying to space out two items, the f7-row and the toggle.
f7-list-item
  f7-row
    f7-icon
    oh-link
  oh-toggle
  1. Use only two items. The oh-link can have both icons and text simultaneously so you don’t need the additional icon component.
I think #2 is probably closer to what you need and a little easier to manage.
component: oh-list-card
config: {}
slots:
  default:
        icon: f7:lightbulb
        title: Title goes here
      slots:
        title:
              iconF7: lightbulb
              text: Title Goes here
              iconSize: 32
              iconColor: black
              textColor: black
        after-title:
              item: some_item
Produces:
You can see that with minimal styling the custom list item matches the oh list item almost exactly. The only downside to this method is the simplicity of the oh-link does prevent you from perfectly matching the alignment of the title text. If 4 or 5 pixels bothers you then you’ll want to try and use solution #1.
Hi Justin,
thank you so much. It is working and I learned a lot from you! Thank you!!!
