- Platform information:
- Hardware: Raspi 4B, 4GB, 128 GB
- OS: raspbian
- Java Runtime Environment: openjdk version “1.8.0_222”
OpenJDK Runtime Environment (Zulu8.40.0.178-CA-linux_aarch32hf) (build 1.8.0_222-b178)
OpenJDK Client VM (Zulu8.40.0.178-CA-linux_aarch32hf) (build 25.222-b178, mixed mode, Evaluation) - openHAB version: 2.5.3.1
- Issue of the topic: DateTime item is obviously mapped in sitemap to display correct daylight saving time. But if I use the same item in rule processing to concat two time strings (sun rise and sun set) I get the wrong time output.
- Please post configurations (if applicable):
- Items: DateTime Sonnenaufgang_Zeit “Sonnenaufgang [%1$tH:%1$tM]” (gSonne) {channel=“astro:sun:local:rise#start”}
- Sitemap: Frame label=“Sonne und Mond” {
Group item=SummarySun label=“Sonne [%s]” icon=“sunrise” {
Text item=Sonnenaufgang_Zeit label=“Sonnenaufgang” icon=“sunrise”
Text item=Sonnenuntergang_Zeit label=“Sonnenuntergang” icon=“sunset” - Rules: var String auf = Sonnenaufgang_Zeit.state.format("%1$tH:%1$tM").toString
var String unter = Sonnenuntergang_Zeit.state.format("%1$tH:%1$tM").toString
logWarn(“sunmoon.rules”,"++++++Ausgabe "+auf)
SummarySun.postUpdate(auf + " - " + unter) - Log: 2020-03-21 14:07:29.464 [WARN ] [smarthome.model.script.sunmoon.rules] - ++++++Ausgabe 04:56
Sitemap displays 05:56 for the item Sonnenaufgang_Zeit which is correct
The item created by the rule (SummarySun) shows 04:56 which is wrong
How can I fix this problem?
regards, Gerald
