Hello.
How can I center Label on widget and reduce space/size of widget?
As a base I used universal_toggle_v3 from marketplace.
uid: universal_toggle_v3_mod1
tags: []
props:
parameters:
- description: Title of the card
label: Title
required: false
type: TEXT
- description: Name of the Icon (see https://framework7.io/icons/ for available icons)
label: F7 Icon
required: true
type: TEXT
- description: Color scheme for icons and toggles (see https://framework7.io/docs/color-themes.html for available color schemes)
label: Color
required: true
type: TEXT
- context: item
description: Main toggle item (use for single toggle or as main switch for group)
label: Item
required: false
type: TEXT
- description: Group toggles (use as group with or without main toggle)
label: Group toggle Array
required: false
type: TEXT
parameterGroups: []
timestamp: Feb 3, 2023, 10:15:15 PM
component: f7-card
title: =(props.title)
slots:
default:
- component: f7-card-content
slots:
default:
- component: f7-swiper
init: true
pagination: "=(props.maintoggle) && (props.grouptogglearray) ? true : false"
params:
slidesPerView: 1
pagination:
clickable: true
style:
width: 100%
height: 100px
slots:
default:
- component: f7-swiper-slide
visible: "=(props.maintoggle) ? true : false"
style:
width: 100%
height: 100%
slots:
default:
- component: f7-col
class:
- display-flex
- flex-direction-column
- align-items-center
- justify-content-space-evenly
style:
width: 100%
height: 100%
slots:
default:
- component: f7-icon
f7: =props.icon
size: '=(props.grouptogglearray) ? "50" : "60"'
color: '=items[props.maintoggle].state == "ON" ? props.color : "gray"'
- component: oh-toggle
item: =props.maintoggle
colorTheme: =props.color
- component: f7-block
style:
height: 35px
display: '=(props.grouptogglearray) ? "block" : "none"'
visible: "=(props.grouptogglearray) ? true : false"
slots:
default:
scrollbar: true
params:
slidesPerView: 1
direction: vertical
mousewheel: true
scrollbar:
hide: true
style:
width: 100%
height: 100%
slots:
default:
- component: oh-repeater
for: item
in: =props.grouptogglearray.split("|")
fragment: true
slots:
default:
style:
width: 100%
height: 100%
slots:
default:
- component: f7-col
class:
- display-flex
style:
width: 100%
height: 100%
slots:
default:
- component: f7-block-title
style:
margin-top: 5px
margin-bottom: -2px
slots:
default:
- component: Label
text: =loop.item.split("\"")[1]
f7: =props.icon
color: '=items[loop.item.split("\"")[3]].state == "ON" ? props.color : "gray"'
item: =(loop.item.split("\"")[3])
style:
height: 5px
display: '=(props.maintoggle) ? "block" : "none"'
