I am running Openhab 3.3 in a Docker on a Synology 920+. Now I would like to install a certificate for the SSL connection for the Openhab Docker.
Essentially, I want to re-establish my connection to my Docker.
The manufacturer has now released and installed a new certificate on the device that is valid until 2031 and also no longer produces a certificate error. With the certificate and the commands
Installation of the certificate for the decalcification system
Loaded the crt to /home/openhabian
export JAVA_HOME=/usr/lib/jvm/zulu-embedded-8-armhf
keytool -importcert -file /home/openhabian/PeterBauer.crt -keystore $JAVA_HOME/jre/lib/security/cacerts -alias Judo
Used the password: changeit
Does the query also work on an Openhabian installation running standalone on a Pi.
Of course, in my main installation on Docker I get an SSL error because the certificate is not installed there.
[enhab.core.model.script.actions.HTTP] - Fatal transport error: java.util.concurrent.ExecutionException: javax.net.ssl.SSLHandshakeException: Abruptly closed by peer
Can you explain how I can execute the command to import the certificate for Synology Docker so that the handshake error no longer occurs?
