- Platform information:
- openHAB version: 3.1.1
- Issue of the topic:
I had an existing Thing, an esp32 board being used to bridge to 1 Bluetooth Low Energy temp/humidity sensor. In openHab it had the code below:
UID: mqtt:homeassistant_349454250230:2d1cd8ee67:349454250230
label: esp32mijiablebridge1
thingTypeUID: mqtt:homeassistant_349454250230
configuration:
topics:
- sensor/esp32mijiablebridge/pvvx_temperature
- sensor/esp32mijiablebridge/pvvx_battery-level
- sensor/esp32mijiablebridge/pvvx_humidity
- sensor/esp32mijiablebridge/pvvx_battery-voltage
basetopic: homeassistant
bridgeUID: mqtt:broker:2d1cd8ee67
Then I updated my esphome config so it would also bridge to a 2nd BLE temp/humidity sensor, of the same hardware type. Updated the esphome config, compiled, pushed the firmware to esp32, and it seemed to work because I see the new data in MQTT Explorer, and in OpenHab the code auto-updated to this:
configuration:
topics:
- sensor/esp32mijiablebridge/pvvx-2_humidity
- sensor/esp32mijiablebridge/pvvx-2_battery-level
- sensor/esp32mijiablebridge/pvvx-2_temperature
- sensor/esp32mijiablebridge/pvvx-2_battery-voltage
But… in the Channels tab of the Thing I can’t see the new sensors (the ones starting with pvvx-2). They’re not in All, they’re not in Unlinked.
So, how do I add them in, please?
