Hello!
At the moment I use openHAB 4.
I have installed a Zigbee power plug as a thing… working very well.
To it a dust cleaner with chargeable batteries is connected.
From the power plug I receive the power in Watts and the current in A.
Now I want to set the power plug to do the following thing:
When for example the power is over 40 Watts it should activate the rule…
When the power is under 20 Watts for about 1 minute it should turn itself off.
With a trigger of a rule this is definitely not possible!
Can you tell me how I can set this up?
Thanks in advance!
Best regards
Tobias
