Hey im pretty new to OH2 but i have managede to get all of my IHC inputs (Switches) mapped in items and it works…
Now i want to use these switch item to turn on my hue lights how do I do this
sorry for the bad english
HI!
You can create one rule, to make what you need.
Map the input resource of the ihc button to one switch, and when this switch changes state do what you need.
Regards!
HI!
could you show me how that rule would look like, my idear on a rule looks likes this but i doesnt seem to work what am i doing wrong
rule "Hue Bulb On/Off"
Item TrykOV7 changed
if (Light2_Toggle.state == OFF){
postUpdate(Light2_Toggle, ON)
else if (Light2_Toggle.state == ON){
postUpdate(Light2_Toggle, OFF)
Best Regards
Christian
To command something to do something (like turn a light ON or OFF), you should use sendCommand:
Item TrykOV7 changed // if this is the correct trigger
Light2_Toggle.sendCommand(if (Light2Toggle.state == ON) OFF else ON)
The item TrykOV7 should be binded to one resource of IHC. Check if the id is correct.
this is from my items file it should be correct since i can see it being activated i Basic UI when i push the button
Switch TrykOV7 “Lyttetryk, Pejs v. Værelse, ØV” (GF_Pejs, Lights) {ihc=“0x6E5c”}
Switch Light2_Toggle (GF_Stue, Lights) {channel=“hue:0100:1:bulb2:brightness”}
Which is the type of the channel “hue:0100:1:bulb2:brightness”? its one number? Maybe you need to set one number instead ON or OFF.
Light2_Toggle.sendCommand(if (Light2Toggle.state == ON) 0 else 100)
I think you need to set one PercentType and not one OnOffType.
Hi jmv thanks for the help so far!!!
Maybe i havn’t fully understood rules yet is there something i have to import to the rules file for bindings to talk to eachother???
No problem, I will help you here I’m able to.
You don’t need to import anything for such a simple rule.
What I can advise you is to make the rule in baby steps.
First try to trigger the rule, and just Log one simple phrase.
Then try to send one command to the hue, to increase the brightness to 100%.
You need to discover where your problem effectively is, if in IHC or in the Hue.
Let me know the results!
Regards
So far so good made a rule (very simple) and it works in UI
When Hue_kontor_on is activated in UI, Light2_Toggle goes on…
When Hue_kontor_off is activated in UI, Light2_Toggle goes off…
rule "Hue Bulb ON"
Item Hue_kontor_on received command
sendCommand(Light2_Toggle, ON)
rule “Hue Bulb OFF”
Item Hue_kontor_off received command
sendCommand(Light2_Toggle, OFF)
so next “problem”… when i am watching the UI while pressing the psysical switch (Hue_kontor_on) it goes ON in UI, but when going ON it doesn’t trigger rule
Any Idea???
SOLVED!!!
The Rule Should look like this
Item Hue_kontor_on changed from OFF
rule “Hue Bulb OFF”
Item Hue_kontor_on changed to OFF
This made it all work…
Thank You All for the help
Great! but looking to the rule you can simplify…
sendCommand(Light2_Toggle, Hue_kontor_on.state)
Regards,
Hey great thanks currently im working on the dimmer rule
could the rule you have given here be used with number values as well???
If you update with decimal values, the channel of the brightness you can dimmer the light. Search the forum and you will find some examples.
Hey again and thanks for all the help
now both the on/off rule and dimmer rule works
Hi RudoX
Will you share how you got i both rule working?
Hi Alexandersen…¨
They are not the most beautiful written rules but they work…
//Hue Kontor
rule "Hue Bulb On 2"
rule “Hue Bulb OFF 2”
rule “Hue Kontor Dim”
Item Hue_kontor_dim changed
var Number tal = Hue_kontor_dim.state as DecimalType
if (Hue_kontor_dim.state instanceof DecimalType) tal = Hue_kontor_dim.state as DecimalType
sendCommand(Light2_Dimmer, tal)
// Bulb2 Kontor
Dimmer Light2_Dimmer (GF_Stue, Lights) {channel=“hue:0100:1:bulb2:brightness”}
Switch Hue_kontor_on (GF_Stue, Lights) {ihc=“2839314”}
Dimmer Hue_kontor_dim “Lys Niveau Hue Kontor” (GF_Stue, Lights) {ihc=“3108371”}
maybe you could help me write a funktionsblok in IHC-Visual that works better than the ones im using
Im also on www.ihc-user.dk
Hi Rudox
Thanks on IHC-User maybe we can do it in danish
I will try to make a blok - is it default LK bloks you use now?
/Christian
I ment original not default
I have made a Hue Funktionblok but i lacks some features i cant quiet figure out how to implement
