Imho you are doing everything correctly.
Maybe create the items for the channels R, G, B (see on very top) and try controlling each channel with a dimmer to ensure, the LED strip is properly connected.
Also can you look inside the openhab/userdata/zwave/device.xml of the z-wave node for the COMMAND__CLASS__SWITCH__COLOR and post it?
obviously the integer for colortype GREEN is not 0 … and the attribute <endpoint reference="../../../.."/>
is missing on my end
I used paperUI to create items for the individual dimmers the other day. I was able control the dimmer of the RED channel. all other channels are not responding. I have the same result on both devices.
I did not try to create items using files. I could try but I don’t expect any difference
I will create items for the individual colors later today using files. I assume you mean with “all of your used items” just all the items that relate to this thing…
Ok, this post is to prevent others to go through the same embaressment as I just did. After extensive testing of all the individual ports of the fibaro controller I suddenly realized that my 12v adapter was in no way prepared to deal with my 24v ledstrip.
I had some problems merging the last changes, but they are now merged. This changes to use the brightness control in the RGB command, but hasn’t yet added the RGBW, indexed mode I suggested. This is quite simple, and mostly coded, so I’ll try and finish that soon.
I’m not sure when the next release is though (or if there is one and you just need to use SNAPSHOTs).
The changes I merged to change the level control (as we discussed previously) are in there - I haven’t done the new channel yet (sorry - I got caught with other things at the moment). I will try and do that over the next few days - if I forget, please feel free to remind me again. It’s 99% done, but I’m running around the house a bit at the moment as we’re trying to sell the house and I have way to much junk that I need to get rid of
Does someone have the same Problem with the rgbw2 that when I dimm the Master to 1% the LEDStrip is off? It only shows (very low light which would be perfect for 1%) on 2%…I can’t find a command class to set minimum brightness…
I’m having the same issue and I’ve configured everything correctly (imho!).
I suspect this is a rounding issue when transferring from percent to the actual value.
Do you also have the case that the device reports “in steps”. That means when I dimm from 100% to 0%, it shows 50% then after one or two seconds 20% and then 0%?
