Platform information:
Hardware: x86_64
OS: Ubuntu 23.10 (mantic), 6.5.0-27-generic
Java Runtime Environment: OpenJDK 64-Bit Server VM Zulu17.50+19-CA (build 17.0.11+9-LTS, mixed mode, sharing)
openHAB version: 4.2.0.M2 (Build)
Issue of the topic: Timers created through blockly rules do not seem to fire. I am attempting to set a 15 minute timer to shut off lights in an area after the last detected motion or switch from two different motion sensors and two different switches.
Please post configurations (if applicable): Generated code from blockly
Items configuration related to the issue: N/A
Sitemap configuration related to the issue: N/A
Rules code related to the issue
if (cache.private.exists('GarageSaver') === false || cache.private.get('GarageSaver').hasTerminated()) {
cache.private.put('GarageSaver', actions.ScriptExecution.createTimer('GarageSaver', time.ZonedDateTime.now().plusMinutes(15), function () {
items.getItem('Garage_Light').sendCommand('OFF');
items.getItem('Shop_Light').sendCommand('OFF');
} else {
cache.private.get('GarageSaver').reschedule(time.ZonedDateTime.now().plusMinutes(15));
Services configuration related to the issue: N/A
If logs where generated please post these here using code fences:
I can not find any logs related to timers. I see rule triggers fire but nothing after the original trigger to suggest that the timer is trying and failing or whatever. I faced this same problem in previous versions of OpenHAB and instead pivoted to doing a persistence query. I would like to move to the simpler rule but could use some help working out how to troubleshoot timers.
rlkoshak
(Rich Koshak)
April 17, 2024, 6:16pm
2
Show the whole rule. Click on the “code” tab so we can see the rule triggers in context.
I suspect that what ever is triggering the rule is doing so more often than every 15 minutes causing the timer to perpetually be rescheduled.
Adding a simple log block as the first block of the script will confirm if that’s the case.
Thanks, I added some log elements right after I sent this. With the logs, I could see that my trigger was never hitting. I had it triggered on the two switches to get the command of ON. Perhaps because of my setup with zwave-js-ui, that command is never coming through. I just changed it to trigger when the motion sensor updates to true. Here is my current version of the rule.
configuration: {}
triggers:
- id: "1"
configuration:
itemName: Garage_Sensor_Motion
state: "true"
type: core.ItemStateUpdateTrigger
- id: "2"
configuration:
itemName: Shop_Sensor_Motion
state: "true"
conditions: []
actions:
- inputs: {}
configuration:
blockSource: <xml xmlns="https://developers.google.com/blockly/xml"><block
type="oh_log" id=",kEwQPyP]G#9Qmc+K6K_" x="156" y="74"><field
name="severity">info</field><value name="message"><shadow type="text"
id="UYU/RLsj`oottSZD6PAT"><field name="TEXT">abc</field></shadow><block
type="text" id="G5;_8k4$Xh0#?l!m.Pm?"><field name="TEXT">Starting or
triggering reset timer for
GarageSaver</field></block></value><next><block type="oh_timer_ext"
id="xbMHn0-xa$vg]+e1io8#"><field
name="delayUnits">plusMinutes</field><field
name="cache">private</field><field
name="retrigger">reschedule</field><value name="delay"><shadow
type="math_number" id="KJYa~?eNX~N[y6]nugl("><field
name="NUM">10</field></shadow><block type="math_number"
id="LV`H]2mXdf=@x/@%t}.Q"><field
name="NUM">15</field></block></value><value name="timerName"><shadow
type="text" id="}WQkIaJ%zU`*V*-vrdTA"><field
name="TEXT">MyTimer</field></shadow><block type="text"
id="d$:3uW5y;5!([oE{tzh`"><field
name="TEXT">GarageSaver</field></block></value><statement
name="timerCode"><block type="oh_log" id="es]-l}xnz;;Jf~2$HXTn"><field
id="N3!tf1nUC_Ct5[ddvXe7"><field name="TEXT">abc</field></shadow><block
type="text" id="ym_A(`L-;%@NBIH*?O02"><field name="TEXT">Executing from
GarageSaver timer</field></block></value><next><block type="oh_event"
id="n.v8`Lq|M[F;T$xTfANy"><field
name="eventType">sendCommand</field><value name="value"><shadow
type="text" id="^_CKNxf)]*w+Y[?PZ=S!"><field
name="TEXT">value</field></shadow><block type="text"
id="JrOh^AYw3^fu^_[`MEJ4"><field
name="TEXT">OFF</field></block></value><value name="itemName"><shadow
type="oh_item" id="K7WL//#W_ca4kN?kI#ed"><mutation itemName="MyItem"
itemLabel="MyItem"></mutation><field
name="itemName">MyItem</field></shadow><block type="oh_item"
id="%P^F,5I2nC-aA}=Es;b/"><mutation itemName="Garage_Light"
itemLabel="Garage Light"></mutation><field
name="itemName">Garage_Light</field></block></value><next><block
type="oh_event" id="y:x8-ti3o`aTY(ots8e}"><field
id="0GZgJ(q0MF0O!(ZVh{}~"><field
id="?DS%SY)s}#r:mu2/n|+z"><mutation itemName="Shop_Light"
itemLabel="Shop Light"></mutation><field
name="itemName">Shop_Light</field></block></value></block></next></block></next></block></statement></block></next></block></xml>
type: application/javascript
script: >
console.info('Starting or triggering reset timer for GarageSaver');
console.info('Executing from GarageSaver timer');
} else {
type: script.ScriptAction
jasonrobey
(Jason Robey)
April 17, 2024, 11:07pm
4
Well, that worked. I was expecting to be able to update a log4j setting to see timer things or hit the embedded database or something. Simply adding log statements in my blockly scripts did the trick.
