How do i do speedtest ookla with openhab2 on windows 10?
I installed speedtest CLI on Windows 10
How do I combine it with openhab2?
The following link should get you started.
Speedtest-cli Internet Up-/Downlink Measurement Integration - Tutorials & Examples - openHAB Community
Thanks but I could not figure out how to write the rules that will fit windows
What errors are you getting? The link has a section for writing the rule by making some changes to the linux rule code.
thanks for your reply,
I found this one:
Speedtest CLI by Ookla - Internet Up-/Downlink Measurement Integration - Tutorials & Examples - openHAB Community
and i’m getting error when i try to START
1
Still a valid question.
I do not know, I followed the instructions
Alright, let’s see if we can help with an error that is a secret.
When you copied the rule from that post, you did also copy the two lines before, and put them at the top of your xxx.rules file?
val String ruleId = "Speedtest"
val Number calc = 125000 // Converting from bits to Mbits
i found this error from log file:
2021-03-19 00:34:33.601 [ERROR] [pse.smarthome.model.script.Speedtest] - --> speedtest failed. Output:
You may only use this Speedtest software and information generated
from it for personal, non-commercial use, through a command line
interface on a personal computer. Your use of this software is subject
to the End User License Agreement, Terms of Use and Privacy Policy at
these URLs:
       https://www.speedtest.net/about/eula
       https://www.speedtest.net/about/terms
       https://www.speedtest.net/about/privacy
To accept the message please run speedtest interactively or use the following:
    speedtest --accept-license
You should read on further in the thread you copied the rule from
Solved :slight_smile:
I added --accept-license after -f json
val speedtestExecute = "C:/openHAB2/speedtest.exe -f json --accept-license"
Thank you for helping me solve this
